Old 10-07-2008, 03:54 PM #1
lnabbster lnabbster is offline
lnabbster is an unknown quantity at this point
Driver's door is stuck shut
Hi everyone- I have a 2004 4runner- driver's door is stuck shut. When you try to manuall turn the key from the outside it only goes to the left- but not to the right to unlock. I can hear the actuator trying to work with the remote. I took the seat out, jimmy'd the panel off the door and I can't figure out how to get the door open so I can work with it. anyone experience this one or have a solution? thanks.
lnabbster is offline   Reply With QuoteReply With Quote
Old 10-07-2008, 04:35 PM #2
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Re: Driver's door is stuck shut
What happens when you unlock it from inside?
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 10-07-2008, 04:54 PM #3
Thanks for the reply- it won't unlock from the inside. I traced the cable from the inside door lock to the actuator and tried to pull on the actuator- but that wouldn't work either. I'm thinking the actuator is maybe broken on the inside or the lock/hinge is stuck. Not sure. wondering if I can get the actuator out of the door while is stuck shut?
Old 10-08-2008, 01:04 AM #4
MikesToy MikesToy is offline
Banned
MikesToy is on a distinguished road
Banned
so what happens when you try to unlock it with your remote?
MikesToy is offline   Reply With QuoteReply With Quote
Old 10-08-2008, 02:39 PM #5
with the remote- same thing- the door won't unlock- u can hear the actuator trying but doesn't work. I'm thinking the actuator is jammed- therefore I'll have to pull it from the inside.
Old 10-14-2008, 01:10 AM #6
Banned
Banned
i wonder how it got stuck in the first place?
Old 10-14-2008, 03:28 AM #7
drmorbius's Avatar
drmorbius's Avatar
Look at the end of the door. There is a set screw which holds the lock cylinder in place. Loosen or remove the set screw, put the key in the lock and wiggle it until the lock cylinder comes out. Release the cables from the inside handle/lock assembly, remove the single bolt which holds the lower rear window guide and remove the guide. Remove the three phillips head screws that hold the latch and the actuator box, and remove the box through the hole in the door.
Larry
Old 06-20-2019, 01:25 PM #8
sketch_milk sketch_milk is offline
sketch_milk is on a distinguished road
I lost my keys while at work, had a spare, non chipped key made. The key unlocked the vehicle, and still locks/unlocks all 4 doors and hatch, but the driver door will not open from the inside or out. Have since found the spare chipped key, but same issue. All doors lock/unlock, but driver door won't open.
sketch_milk is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 08:10 PM #9
bettschatz bettschatz is offline
bettschatz is on a distinguished road
4 runner drivers door stuck ...
Helpppp ... door inexplicably will not open. Actuator works ... lock and unlock works on all doors except, of course, driver’s side. Am sooooo frustrated, I think my neighbor enjoys seeing me clamber in to the drivers side from passenger side... lol
bettschatz is offline   Reply With QuoteReply With Quote
4runner to the rescue of a plow driver (stuck in about 12ft drift) scottp999 General Discussions 3 02-20-2010 06:33 PM
Stuck twice ... Lock diff as soon as I hit dirt? KrazedJD Off-Roading 19 08-16-2009 12:04 PM
driver's side window problem sahtt Classic T4Rs 5 07-30-2006 12:56 PM
Northeast still has dumbest drivers Thai 4th Gen T4Rs 22 06-12-2006 06:41 PM
BMW Drivers Get Most Sex! Thai Off Topic 2 05-03-2004 10:30 PM
