11-10-2008, 01:36 AM
#16
Try some of these suggestions that members are giving you. get busy.
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
11-10-2008, 03:44 AM
#17
I agree. Do what others have told you.
Though Toyota might be trying their best, you've been rigless for 5 weeks. unacceptable.
NHTSA MUST be notified of this problem.
The lawyer part is up to you.
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
11-10-2008, 10:29 PM
#18
I have been refraining from replying...for the following reason; you continue to ask us what to do and I know myself and others have provided you with options. We cannot fix your problem and ultimately it is up to you on what you personally find acceptable. I don't mean to insult or offend or belittle...etc. I just mean to state you have to figure out for yourself how much BS you are willing to put up with. That being said:
Personally I would take comfort in knowing that the dealer has been able to reproduce the problem. That can be one of the most difficult things to do. Being able to reliably reproduce and issue at least makes certain they can retest for the problem. It also ensures that the problem has most likely been fixed when no longer reproducible. Now, I would still have them replace the wiring harness and everything else brake related. Another thing to consider if they haven't already is the VSC system. I am not sure how much of this is tied to which systems they have and have not replaced. But the computer senses when you are turning and decides if the vehicle is not going the direction you are pointing it, it attempts to brake the wheels and cut power to the engine. This system does use the brakes. Not necessarily the cause, but something to consider.
Now have you contacted Toyota Corporate? I mean they have had your rig for 5 weeks man!!!! Are you in love with your rental Camry or something? Really, if they did this to me I would ask that they make 1.25 months of car payments.
Also you really need to contact the NHTSA. These people need to be aware of the incident. I already provided a link in a past post. You can tell them what happened, what the dealer has done thus far and if it was fixed or not. Imagine if you don't file this complaint and someone else gets hurt because there is a similar problem. Seriously...CONTACT THEM!
Best of luck and keep us all updated to the final solution!
Schuyler
My Rig: 2007 Limited V8 (Nautical Blue) | Front Lift & Sliders: Downey Kit | Rear Lift: OME 896 (Heavy with Nitro Sport) |Skids : BudBuilt | Bullbar : Shrockworks| Winch : Warn 9.5XP Amsteel Line | Lights : PIAA 580s | Tires : 265/65 BFG TA/KOs on 18" Stock Wheels | Audio : VaisTech Video iPOD Kit for Factory Nav | Newest Addition - BajaRack | June T4ROTM (Thanks guys!)
11-10-2008, 11:01 PM
#19
like he said. Squeaky wheel gets the grease.......
good luck with this. It is important.
Yakima Load Warrior
Bilsteins 5100's
11-24-2008, 01:33 AM
#20
Just an update for you guys,first off when dealing with a dealer it was really bad advice to give someone to call a lawyer,i think i got alot farther with just being nice and understanding so you guys should all think about that!!!!well it ended up being a steering wheel postion sensor,with that installed the truck now drives great will pick it up at the dealer monday,thanks for all the great advice...????? shuly
11-24-2008, 02:23 AM
#21
well speaking just for myself, I was not to concerned about your little arrogant whiny reports, however I was concerned about people on the road who you put in danger by not dealing with it as the safety issue it clearly is.
That said, you asked the forum who are a group of people who I happen to like for opinions and you got them To turn around and smack the members for giving you that advice (some of which was more than appropriate) and based upon a grave level of concern is simply chickensht. That said, I am glad that you were able to catch more flies with honey than vinegar. You might try that same tactic here on the members area unless you think that cyberspace is somewhat less deserving of your skills. It takes quite a bit to tick me off but you have.
Try buying a vehicle next time that fits your personality. Maybe something strong like a LOTUS> lots of trouble usually serious.
Yakima Load Warrior
Bilsteins 5100's
11-24-2008, 03:26 PM
#22
Super Moderator
Super Moderator
[COLOR=darkblue]Regardless of the banter about how to deal with the dealer, Toyota etc. thank-you for updating us with regard to the steering wheel position sensor. Hopefully nobody else will deal with the problem you had but maybe your reply will help somebody else should a similar problem arise.
I am very surprised that the bad signal didn
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
11-24-2008, 10:00 PM
#23
I am glad it all worked out well and that everyone is safe and sound...and most happy that you have your rig back Now go out and have fun!
08-06-2018, 06:10 PM
#24
Ok guys, new to the forum. So new I can't even start a new thread 😏... But I'm looking for help on an ABS system on a 2003 Limited with 4.7. Is the ABS light, VSC, and TRAC lights supposed to come on when you initially turn on ignition switch?
08-06-2018, 06:27 PM
#25
Here ya go.
VSC/Traction Control/ABS/VSC TRAC lights
Yakima Load Warrior
Bilsteins 5100's
08-06-2018, 06:38 PM
#26
Originally Posted by alaskaman
That's the thing, it all started the first weekend I had the truck and went wheeling with a buddy that owns a GX470. He showed me how the ATRAC worked on his GX so i tried it in my 4 Runner but i couldn't ever get the brakes to grab on the free spinning wheels. I tried 4 Hi, 4 Lo, diff locked etc. So weeks of research have led me to cheking the ABS and other components. I've called 4 dealerships, 3 in Birmingham and one in La Grange, and all the techs say all the lights are supposed to cycle when ignition is turned on. It's like my ABS isn't getting power. Even when I unplug the connector on the brake controller that causes traction, VSC and ABS lights to come on, nothing happens
08-06-2018, 08:21 PM
#27
Since your lights don't come ON I would start a new thread when you are able.
Yakima Load Warrior
Bilsteins 5100's
