11-16-2008, 01:29 AM
Power rear window problem (4th gen)...
My rear window hasn't been working for a while (and NO the window lock button isn't pressed in). It's not obvious which fuse the rear window is on, so I checked all of them, and they all look OK.
Anybody know for sure which fuse it's on, or if there's any other obvious things I should check before I go to the next step?
2004 4Runner V8 LTD
Kenwood DNX 6160, K&N Air Filter, ss exhaust tip, Compustar Pro Alarm/Starter, westin bull bar + piaa lights
2009 Subaru Legacy 2.5GT spec B
Stage 2
11-18-2008, 10:51 PM
Fuses
I would try replacing the right fuse anyway. Sometimes fuses will appear to be OK but are not.
11-19-2008, 08:30 AM
See the attached diagram. The rear window and side windows are on the same 30A POWER fuse under the dash. Do your side windows work OK? Does it work with any of the 3 ways to trigger it (dash switch, key fob or physical key in rear hatch?)
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
11-22-2008, 03:59 PM
Duh, I should've tried those before posting, totally forgot since I don't use the factory key fob, and never tried the key to operate the window...
Both of those methods WORK properly. With key in hatch, window goes fully down and fully up. Key fob lowers window when vehicle is unlocked as it should.
I guess there might be a bad connection in the switch up front then?
Kmvreter thanks for the attachment, that should come in handy!
2004 4Runner V8 LTD
Stage 2
01-07-2009, 07:03 AM
Took it in to the dealership for it's final pre-warranty expiration service. Had them look at the rear window switch. They said they could not operate the window by any of the 3 possible ways. I was surprised, and told them the key recently worked for me as did the key fob window down button. But when I tried to show them, neither of those methods worked. They say it needs a new ECU. Cost is around $300 installed. Lucky me, again. (last year I had to cough up $1200 for a new rear air susp. ECU and sensor)
2004 4Runner V8 LTD
Stage 2
01-07-2009, 07:11 AM
Oh and my rear defrost/side mirror defrost doesn't work either. I read somewhere that it doesn't work if the rear window is down, so maybe my rear window is not quite 100% up and has disabled it. Hopefully when I replace the ECU this problem goes away too....
2004 4Runner V8 LTD
Stage 2
01-07-2009, 07:32 PM
That's correct.
So is this covered by warranty?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
01-24-2009, 11:07 AM
No, none of those ECU's or electrical components are covered by the powertrain warranty unfortunately.
2004 4Runner V8 LTD
Stage 2
01-25-2009, 10:44 PM
Banned
Banned
Re: Power rear window problem (4th gen)...
Maybe its not the fuse problem. Have you try taking out the door panel and check inside of door? Maybe its the window motor.
08-14-2018, 06:06 PM
Nice necro, bro
New around here, but I believe the preferred method is posting in established threads rather than starting new ones...
2003 Limited, 150k, V8 4wd
Situation
I have lost power to my rear window: window will not go down with fob or dash button, window lock button is not depressed, and rear windshield wiper does not respond. I tried the "hold the dash button up 15sec then down 15sec" without any change. I've called the fuse box several less than flattering names, without improvement of the situation.
Background
I'm admittedly a novice on auto repairs, but I understand the concept of replacing fuses (having blown one when replacing my interiors with LEDs.)
Assesment
Could this be the source of the issue? All fuses that I have pulled whose descriptions even mildly reference rear, power, or window, look to be in tact. If this is a fusaroni, which one?
Computer halp!!
09-26-2018, 10:36 AM
Same situation here:
Rear window will not go up or down with any function (fob, switch, key in lock)
Rear wiper and washer not working
Rear defrost does not work
Door opens and locks as usual
I have tried multiple things and variations of things as well:
Disconnecting battery and attempting to reset
Looked at all the fuses
Removed the back panel and tried to find any cracks/breaks in wiring
Pulled the roof panel down as well to see if anything was amiss
Read about "resetting the breaker" in a circuit breaker next to the fuse box. Didn't see anything that could be considered a reset for a breaker.
Playing with the rear wiper while trying to raise the window
Pushing the switch and then trying to raise the window, in case it is not fully up
Nothing works. I can hear clicking from the hatch when I attempt to raise or lower the window with the dash switch but hear nothing when using the fob or key in the rear lock.
I pulled the panel off again last night and looked around and there is some corrosion on the window regulator and components. There is no rust on the door itself so i figure the seal on the rear window was letting in moisture.
I have looked at replacing the window motor and the wiper motor but damn, those things are expensive. I have even been shopping around for a complete rear hatch but after reading some other posts, I don't know if that will rectify the problem either.
For a couple of months before, the wiper was working intermittently or would stutter before it started so now i wonder if it that is pooched and somehow it is affecting the window and other functions?
Has anyone else had any luck in replacing the wiper motor and then miraculously, everything eslse works?
Thanks guys
03-11-2022, 06:38 PM
Thanks guys
Reviving this old thread. I'm having this same issue. It just recently started happening and no method of rolling the window up or down is working (dash button, key fob or key in the rear door). I also noticed my rear defroster isn't working, the rear wiper isn't working, and the rear washer nozzle isn't working. Essentially the only thing working on the hatch is it locks and opens fine. Did anyone figure out if replacing the rear wiper motor fix all these issues? I read that if you can manage to get the rear window to fully roll down and back up it will make the rear wiper, nozzle, and defroster work again. Let me know if this is the path I should take since I know the window lock button is not on and all the fuses are good.
09-10-2022, 01:12 PM
Rear window hatch
Hey guys I have a situation a little bit different from the rest. My rear window has a mind of its own. Some days it will work perfectly fine and other days it won’t open and it’s not any of the safety features, I don’t have the rear whisper I or anything like that, it’s not my window lock and it’s not any of my fuses. All the other windows work properly too. I’ve opened it up numerous of times to check for bad wiring or bad relay or even the motor and all looks great and works fine. When it starts working again it works perfectly, no lag at all. I also hear the click in the back when I press the button, ohh and also my defrost doesn’t work either when the window stops working. I have noticed that when it rains really hard the next day it doesn’t work and it won’t work for up to a week or two and then randomly one day it’ll work again
09-11-2022, 10:41 AM
Real Name: Skip
Real Name: Skip
Check all the connectors in the rear hatch for a good connection, they could have a bit of corrosion on them, I know the defroster connector especially can be corroded, it's what has cause some of the hatch windows to shatter on 4Th Gens because the corrosion causes the connector to get hot and the heat expands that corner of the window until it breaks, Toyota had a "enhanced warranty extension"/recall and replaced any glass that broke prior to (had to show a receipt of the replacement glass) and during the extension period.
May be your problem or not but worth unplugging the connectors cleaning if needed and reconnecting them, even if they're not corroded they still could not being making a good connection.
2004 Limited V8
09-11-2022, 04:36 PM
Aright I’ll check all of them and see if that helps. Hopefully that is where my problem lies. Thanks for the advise!
