Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 06-13-2012, 06:12 AM #16
Northern Bigdoggy Northern Bigdoggy is offline
Northern Bigdoggy is on a distinguished road
Originally Posted by RevoRunner View Post
Love this forum... thanks. Fixed it for me. After reconnecting... I did have to do the lock... unlock thing 3 times from the driver side too.
What exactly did you do as far as the unlock think 3 times? did you just hit the unlock button on the driver side door 3 times and that was it, or was it a combo of unlock/lock each 3 times? I am hoping that this works if i can figure out what order of unlcok thing you did. So after unplugging battery, the rear hatch opener would not open the tailgate until you did this unlcok procedure you are referring too? thanks....
Northern Bigdoggy is offline   Reply With QuoteReply With Quote
Old 05-05-2013, 12:08 PM #17
chuntmd chuntmd is offline
Real Name: Chris
chuntmd is on a distinguished road
Real Name: Chris
After a rear camera install, same issue. A 3 driver's lock/unlock combo did nothing. Pulled the neg battery (I've just set the preset on the new HU ;)
Over night, reconnected the neg. Nothing. Then did the 3 unlock/lock combo and viola!
CEH
chuntmd is offline   Reply With QuoteReply With Quote
Old 09-27-2013, 12:32 PM #18
rossinboulder rossinboulder is offline
rossinboulder is on a distinguished road
Battery Disconnect & Door Unlock/Lock Worked 2003 4Runner
Thanks! I never would have come up with solution w/o this forum. You guys rock!
rossinboulder is offline   Reply With QuoteReply With Quote
Old 09-26-2014, 09:46 PM #19
Try cleaning the positional sensor if tailgate door wont latch
I have a 2003 4-runner whose tailgate latch stopped working. Just a follow up. The disconnect battery followed by 3 lock/unlock worked for a while, but then the problem came back after the first time I opened then closed the hatch again. So, I took off the tailgate plastic panel, removed the latching mechanism. The mechanism has a tiny plastic postional sensor (has 3 small wires coming out, is attached by 2 small philip's head screws. I then used a can of compressed air used to clean computer keyboards and such and directed the blast of air into the 4 tiny holes in the face of the sensor. Then I worked it back and forth several times and cleaned again. I put it all back together and now the door latches fine. We'll see how long it last this time!
Old 05-30-2015, 01:54 PM #20
Claydn Claydn is offline
Claydn is on a distinguished road
Tailgate won't open
Thanks for the tips in this post. I have an 04 4Runner that was having this exact problem. I unhooked the battery, and it started working again. It stopped shortly thereafter so I used WD40 on the lock and unhooked the batter again, and everything seems to be working great.
Claydn is offline   Reply With QuoteReply With Quote
Old 11-22-2016, 03:21 PM #21
jmriott jmriott is offline
jmriott is on a distinguished road
Originally Posted by Mark86 View Post
How about unplugging/replugging the battery? Maybe it is a stupid glitch that this would correct. Even though it is a long shot, I like starting with the simple things.
Mark86 thank you so much for this solution!!
I just installed a backup camera on my 06 V8. I unplugged the harness connecting the ecu to the latch motor. When I reconnected the latch would not work properly. It would manually latch w/ a loose fit. Opening required doing it manually.
I disconnected the battery for 5 minutes , reconnected & the latch works perfectly.
jmriott is offline   Reply With QuoteReply With Quote
Old 11-29-2016, 11:40 PM #22
blue_crush's Avatar
blue_crush blue_crush is offline
blue_crush is on a distinguished road
blue_crush's Avatar
I just bought my first 4Runner (2000) the other day and mine didn't work either. I will be trying this fix as well. Juuuuust after I fix the rotted rusty frame.
Thanks again.
blue_crush is offline   Reply With QuoteReply With Quote
Old 12-12-2016, 09:10 PM #23
timt4617 timt4617 is offline
Real Name: Tim
timt4617 is on a distinguished road
Real Name: Tim
Hello. I had this problem and disconnected the battery. Upon reconnecting, it worked, but only once. Any ideas?
timt4617 is offline   Reply With QuoteReply With Quote
Old 12-12-2016, 10:00 PM #24
You didn't indicate how long you left your battery disconnected I would try disconnecting the battery for at least 5 to 10 minutes and then retrying the tailgate again other than that I have no further recommendations
Please let us know how this works out
Old 02-01-2017, 10:41 PM #25
jpbz28 jpbz28 is offline
jpbz28 is on a distinguished road
This is why I love this forum!
I'm new here, and hoping to make a positive impact at some point, but for now, I just want to thank everyone who posts resolutions. I installed a rear view camera and my tailgate wouldn't work after. Disconnected the battery, waited 5 minutes, problem solved! Thanks everyone!
jpbz28 is offline   Reply With QuoteReply With Quote
Old 06-11-2018, 01:09 PM #26
RS4runner RS4runner is offline
RS4runner is on a distinguished road
My tailgate just stopped working for no reason on my 2004 4Runner and because of this forum it is now fixed with out going to the dealer. I just disconnected the battery for 5 minutes and now it’s working! I never comment on forums but that just saved me tons of time and money. Thanks!
RS4runner is offline   Reply With QuoteReply With Quote
Old 10-28-2018, 01:32 PM #27
Sorianex Sorianex is offline
Sorianex is on a distinguished road
It worked!
Thanks everybody for the post and fixes. I had the same issue and disconnecting the battery did the trick!
Sorianex is offline   Reply With QuoteReply With Quote
Old 09-14-2019, 01:58 PM #28
gp4Jesus gp4Jesus is offline
gp4Jesus is on a distinguished road
It worked for me on my ‘06 2WD Ltd... ...for about two weeks.
I’ve tried cycling the locks 3 times locked/unlocked by both the driver’s door and the hatch lock numerous times today; window up and down. Do I HAFTA disconnect my battery again?!
Toyotas - I own 4 of ‘em! Recently, for a few days, could honestly say FIVE including TWO Highlanders. Great vehicles. Some really strange solutions...
Thanks for a great forum and in advance for your help
2006 4Runner Limited, V6, 2-wheel drive, 207K miles.
JBL Sound system - best factory system I’ve ever heard. Rivals the DIY aftermarket I designed and installed back in the 80s.
gp4Jesus is offline   Reply With QuoteReply With Quote
Old 09-15-2019, 08:23 PM #29
To whom it may concern,
Disconnecting the battery did I the trick... ...for now. I made sure it wasn’t a one-time thing by opening the hatch 3 X.
Until next time... Tony
Old 09-15-2019, 09:47 PM #30
Help?! Now the key won’t operate the rear window!
Tailgate open height skybum02 5th gen T4Rs 8 02-20-2022 11:17 PM
'98 Rear Tailgate Won't Open DGIL4RUN Problems & Warranty Issues 4 12-16-2013 08:14 PM
how to open tailgate jonboi420 General Discussions 0 08-27-2010 11:23 PM
HELP! Tailgate wont OPEN! A10MileHusker 4th Gen T4Rs 3 12-12-2008 03:06 AM
Open the tailgate? bajjer9 Classic T4Rs 3 11-09-2004 05:03 PM
