Old 08-09-2009, 02:48 PM #1
Trdsupranick's Avatar
Trdsupranick Trdsupranick is offline
Trdsupranick is on a distinguished road
Left Blinker Problem *NEED HELP*!
Hi all,
Hope the summer is going awesome for everyone!
I noticed yesterday when I locked my truck with the fob..the left blinker turn signal light was not flashing.
I jumped in the car and used the left turn signal and the turn signal light was not flashing and the green arrow on the dash was clicking reallly fast . I tested the right turn signal and everything worked normal and the green arrow moved normal and blinked fine.
This afternoon I jumped in and the left turn signal works and the blinker works normal now??? It seems fine? What was the problem??
What do you think this is? Bad fuse? Bad turn signal bulb? loose bulb? I am nervous now that there is a issue.
Any Ideas? What should I do?
Silver 2004 V8 SE Leather
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
Trdsupranick is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 02:50 PM #2
morphius909 morphius909 is offline
morphius909 is on a distinguished road
The fast turn signal to me indicates the fuse for the turn signal is going. At least all the other cars I've owned I've found this.
Have a look in the T4R manual and see where the fuse is.
I'm sure others on here will offer more indepth insight.
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
morphius909 is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 03:38 PM #3
borgzman's Avatar
borgzman borgzman is offline
borgzman is on a distinguished road
borgzman's Avatar
.. left turn signal and the turn signal light was not flashing and the green arrow on the dash was clicking reallly fast ..
Were both front and rear left turn signal light not flashing? also do you have DRL in your turn signal lights?
2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs
2003 SR5 V8 - Sold
borgzman is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 04:19 PM #4
MikesToy MikesToy is offline
Banned
MikesToy is on a distinguished road
Banned
Check both. Bulbs and fuses.
MikesToy is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 04:37 PM #5
toto toto is offline
toto is on a distinguished road
First place I'd look is the bulb.
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 04:51 PM #6
Banned
Banned
I'd look at the fuse first. It's easier to get into and replace.
Old 08-09-2009, 11:39 PM #7
Mark86's Avatar
Mark86 Mark86 is offline
Super Moderator
Mark86 is on a distinguished road
Super Moderator
Mark86's Avatar
I am 100% sure that it is the sign of a failing bulb. The blinker should flash very quickly if one bulb is burnt. On my parents GX, the left signal bulb started to fail intermittently and finally went a week or two later. This occurred when the truck was 1 year old.
It is funny because the left signal bulb decided not to work for 30 minutes during our road trip. Luckily, it came back on after an hour or so. I am starting to wonder if this issue was related to the severe rain storm we drove through.
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
Mark86 is offline   Reply With QuoteReply With Quote
Old 08-09-2009, 11:50 PM #8
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
It would be a bulb or wiring problem, fuse would cause multiple lights to be out.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 08-10-2009, 10:08 AM #9
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
Most likely a bulb issue. The filament in the bulb is broken on one side and re-attaching itself every now and then.
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 08-10-2009, 11:15 AM #10
SubSonic SubSonic is offline
SubSonic is on a distinguished road
Agreed it is likely a bulb issue. 'Fast blinking' indicates a malfunctioning or burned out bulb 99% of the time - on all modern makes and models.
If it were the fuse, it would not be affecting just 1 bulb (would likely be affecting all turn bulbs on all corners, parking lights too, maybe even more).
If it happens again, park, check to see which lights are working and which aren't. My bet says it is a lone turn signal bulb.
2008 Limited 4WD V8 - Titanium Metallic
Factory Nav Sys, Moonroof, Adjustable Height Control, X-REAS, most everything but rear-seat DVD system...Sirius Sportster 4 controlled via Nav Sys with Sirius Toyota interface and SVCDOC1
SubSonic is offline   Reply With QuoteReply With Quote
Old 08-10-2009, 08:10 PM #11
Thanks guys for all your info!! I will check the fuse...and the bulb....and give a update...hope its the fuse..
is it hard to get into the left turn signal bulb casing?
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
Old 08-10-2009, 11:46 PM #12
Mark86's Avatar
Super Moderator
Super Moderator
Mark86's Avatar
You can either access the bulbs from under the hood or from underneath the truck. It is not too hard.
Mark
Old 08-12-2009, 02:59 AM #13
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
It's going to be a bulb, more likely than a fuse.
I disagree, it's much easier to check a bulb. Put the signal or hazard on and do a walk around.
Most Japanese cars when the signals flash rapidly, it's a indication a bulb has gone out. You should replace the bulb quickly as extended rapid flashing will shorten the flasher's life.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 08-12-2009, 06:47 AM #14
Thanks!....The bulb it was! Took 5 mins.!
3/2 Cornfed lift
Spidertrax spacers
33" Cooper STT's
Old 05-31-2015, 04:56 PM #15
Santa Fe Runner Santa Fe Runner is offline
Santa Fe Runner is on a distinguished road
Turn signal is out but don't think it's the bulb/fuse
Hi all,
I have the same problem with my 04 except it's with the right side turn signal. It is also DRL. I've tried replacing the bulbs, I checked the fuses and no
problem, and I even replaced the bulb connector! Nothing has worked that I've tried. The back blinker is working but it's blinking really fast and as well as
the green arrow on the dashboard. Do I have a wiring or grounding problem? Help!!!
Santa Fe Runner is offline   Reply With QuoteReply With Quote
