Old 10-14-2017, 02:47 PM #16
Jaminhdds Jaminhdds is offline
Jaminhdds is on a distinguished road
Same problem!!
We have a 1998 4-Runner that is frustratingly doing the same thing as mentioned above- massive power loss when accelerating after the engine is warmed up. We have done the following to address the problem, but no resolution:
-new fuel filter and pump
-new coils and plug wires
-new MAF sensor.
Any other ideas??
Jaminhdds is offline   Reply With QuoteReply With Quote
Old 11-18-2017, 12:30 PM #17
BusyDadOf7 BusyDadOf7 is offline
BusyDadOf7 is on a distinguished road
Idles fine. No power
99 runner 225k miles. Was idling rough and would stall when idling and rolling like after going over a speed bump or even coming off the highway!
With better gas it happened less often. So I gave it seafoam in the tank. Still happened. Did seafoam spray in the intake. No white smoke and I think I did it wrong - no codes!
- clean MAF
- cleaned intake
- cleaned IAC
Worse!
- replaced plugs and wires
Back to smooth idle - no power.
All ideas welcome!
BusyDadOf7 is offline   Reply With QuoteReply With Quote
Old 03-12-2018, 11:57 PM #18
jlandrey jlandrey is offline
jlandrey is on a distinguished road
timosabe,
i am having the exact same issue.
have you figured out the cause yet?
i cannot seem to get to the bottom of it.
no shop, not even the dealer, can diagnose....
jlandrey is offline   Reply With QuoteReply With Quote
Old 03-13-2018, 11:42 PM #19
Amcneela Amcneela is offline
Amcneela is on a distinguished road
Same problem as Timbosabe!
Timbosabe Did you ever figure this out? my 95 4runner does the exact same thing!
Originally Posted by Timbosabe View Post
Along these same lines, my son has a 2001 4runner which runs great until the engine heats up a little. (90 minutes into the drive maybe during winter or maybe 30 minutes into an errand in the summer) Then after being stopped for a traffic light, he presses on the accelerator and there's nothing there. (as other guy described "falls flat on its face") If you hold the accelerator down it eventually starts taking off at its own pace. Or he could be on the freeway driving fine and he hits the pedal to pass, and nothing happens. If cruise control is set on 70, then it might drop to 55 all by itself. It is throwing no codes whatsoever, so every shop says, if it's throwing no codes, then we can't fix it. Colder weather, it almost always runs great but with warmer weather it acts up much sooner. So is it possible it could be the mass air flow sensor...?
Amcneela is offline   Reply With QuoteReply With Quote
Old 03-13-2018, 11:47 PM #20
1995 4runner same problems!
Exactly as described by Timbosabe.
Have any of you tried popping it into low gear, and then back into drive at a stop? It works perfectly but have no idea what the problem is. Only hesitates in 1st gear off a stop
Old 03-15-2018, 02:29 PM #21
Tracyberkey6 Tracyberkey6 is offline
Tracyberkey6 is on a distinguished road
Forgot to mention we have had the throttle body cleaned but this has done nothing.
I have the same problem, but only when its cold and first starting out and only in 1st gear.
I felt that it was either am airflow problem or a throttle body issue. Throttle body was just serviced, so I went out this morning and took off the air filter and left the housing open.
It worked 90% better immediately!!!
Still a bit sluggish at the very beginning of acceleration, so am heading to get a new Mass Air Flow Sensor.
Im betting this will fix it!
Tracyberkey6 is offline   Reply With QuoteReply With Quote
Old 06-11-2018, 09:02 PM #22
Jshaver.1 Jshaver.1 is offline
Jshaver.1 is on a distinguished road
Has anyone figured out the no acceleration...feels like neutral?? My trans fluid looks and smells great....truck starts rigjt on and idles great everytime...but i xant drive because the truck will just rev and bot accelerate....i start...put in reverse and if im on a hill it will roll forward like its in neutral...then i shut it off...start back up..put in reverse and it back out fine...put in drive and it will either creep witj high rpms and then not upshift...or it just sits there and revs....i feel like this could be something simple....when this happend i was driving aboit 50 mph and it just stopped accelerating....i pulled over ..started back up and it drove fine....3 miles later did it again....there were no noises...no bad feeling...no grinding or slipping...just smoothly revs and doesnt go anywhere...if i push it to about 3000 rpm it will start moving slowly but will not upshift
I am clueless on this.....i do. H
ave a code p0125..insufficient coolant temp closed loop...a lil sludgy in bottom of overflow...but no signs of milkshake in tranny....tranny fluid is perfect
Jshaver.1 is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:34 PM #23
gbettancourt gbettancourt is offline
gbettancourt is on a distinguished road
Same issue.. Throttle body?
-new MAF sensor.
Any other ideas??
First of all, I'm surprissed with all the support in this forum!!
Same issue in a '03 4-Runner, new fuel filter and pump, but after that i've been reviewing and I think that could be the throttle body. The tricky here is that after some time driving and pressing the accelerator with no response seems that the problem dissapear and the 4-runner runs good again..
Did anyone change the Throttle Body?
PS. No codes here, but haven't scann it on a toyota dealer, just particular.
Last edited by gbettancourt; 03-19-2019 at 08:35 PM. Reason: I've miss one detail on the post.
gbettancourt is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 10:30 PM #24
e85rsx e85rsx is offline
e85rsx is on a distinguished road
i have a similar problem .. truck is super charged gen 3 and while accretion it gets to about 3k rpm and starts surging and will not continue to accurate .. car feels super slow, did new plugs, new cats, car has no codes, and put a new maf????
e85rsx is offline   Reply With QuoteReply With Quote
Old 08-10-2019, 07:29 PM #25
GlockSpitting GlockSpitting is offline
GlockSpitting is on a distinguished road
Any luck? Having similar problem. Hearing a whistling noise when accelerating and when I do step on it rpms go up but no acceleration. If I step on the gas softly i have no issue.
GlockSpitting is offline   Reply With QuoteReply With Quote
Old 11-08-2019, 01:03 PM #26
tsheaby tsheaby is offline
tsheaby is on a distinguished road
So this just happened to me while on a 650mi road trip.
Every time I hit a bump in the highway, I would suddenly loose power.
Turns out it was a fuse that had popped out and became loose. Wow!
tsheaby is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:23 PM #27
Paul O'Brien Paul O'Brien is offline
Paul O'Brien is on a distinguished road
Originally Posted by RUNNINIT View Post
I have a 2000 limeted 4runner with 85000 miles on her and when i step on the gas she falls flat on her face does'nt matter at what speed i'm at or if i'm parked same result. I did however cleaned the MAF and put new plugs in and air filter same thing still no power when give it more than half the throttle. Otherwise it rives just fine starts up great everthing else is working great. Getting ready to lift it 2.5" and put some bigger tires on so i would like to have the power for the bigger tires.
I too have a similar issue.I have a 2002 Limited 4runner, I get the slip indicator light come on ususally when I'm turning left, and lose power completely.
Any help would be greatly appreciated.
Paul
Paul O'Brien is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 03:54 PM #28
BLANKOHA BLANKOHA is offline
BLANKOHA is on a distinguished road
Any codes? Possibly a clogged catalytic convertor.... Sarkari Result Pnr Status 192.168.1.1
BLANKOHA is offline   Reply With QuoteReply With Quote
