Did they clear the codes for it? My VSC TRAC OFF light was on when my engine light came on as well - I was misfiring on number 3 cylinder. They replaced the plug, cleaned the coil, and it runs great. Both lights went off. Without knowing what you drive, do you have the center diff lock button to the left of the steering wheel? If so, make sure you have not pushed it by accident. When pushed, it will display the VSC TRAC OFF light. Also, you do not want to be driving around on the highways with the diffs locked, if that is the case. To disengage, push it and hold it in until the light goes off.
02 Limited 4wd: Procomp MT's, Black Cragar Soft 8 wheels, 1.5 body lift, OME 891 rear coils, BudBuilt skid plate, 1" diff drop, custom made bumper, sliders, Rancho Quiklift system front and RS9000XL's rear, EBC pads and rotors, KC SlimLites, Smittybilt XRC8, 1.5 wheel spacers, SONY XPLOD double din cd/receiver with 280 watt spkrs.
"There is no hunting like the hunting of man, and those that have hunted armed men long enough, never care to do anything else." Ernest Hemingway
