Old 01-21-2010, 12:48 AM #1
604Jay 604Jay is offline
604Jay is on a distinguished road
V8 exhaust manifold
I have a 2005 V8 4runner
When I start the engine from cold there is a ticking sound that comes from tne engine when I press the gas. This sound goes away after about 5-10 minutes of driving. It's been suggested that it might be a cracked exhaust manifold.
I'm I doing any harm to the engine if I don't get this fixed? The sound is annoying at first but it goes away. I don't want to spend the money right now if it's not doing any harm to the engine.
Thanks for any input
604Jay is offline   Reply With QuoteReply With Quote
Old 01-21-2010, 12:57 AM #2
cknsls@adelphia cknsls@adelphia is offline
cknsls@adelphia is on a distinguished road
I have it too...
The V8 is a great engine.....but it is A VERY noisy motor! Don't worry about it!
cknsls@adelphia is offline   Reply With QuoteReply With Quote
Old 01-21-2010, 02:28 AM #3
b.abe825's Avatar
b.abe825 b.abe825 is offline
b.abe825 is on a distinguished road
b.abe825's Avatar
Could it be the catalytic converter warming up?
04 Silver Limited V8 4x4 = Love it
Gig'Em Ags! WH09P!
b.abe825 is offline   Reply With QuoteReply With Quote
Old 10-30-2010, 09:20 PM #4
nasher nasher is offline
nasher is on a distinguished road
I do have a cracked right side manifold, wont pass inspection in MA, dealer quote is 1,500 to replace including parts.
nasher is offline   Reply With QuoteReply With Quote
Old 07-28-2011, 04:56 PM #5
saberone saberone is offline
saberone is on a distinguished road
manifolds
Took my 03-v8 to dealer today . Said I need both manifolds replaced . Cost around $3000.00 . First they said it was under warrenty then came back and said no . I;m soooo pissed . I have never had this problem with other vehicles . Yes it is 8years old but only 66,000 miles . Maybe its time to go back to old brand I never had these problems . And to top that off my mech. says my rack is going . Sorry need to vent .
saberone is offline   Reply With QuoteReply With Quote
Old 07-28-2011, 06:47 PM #6
Rix's Avatar
Rix Rix is offline
Rix is on a distinguished road
Rix Rix is offline
Rix's Avatar
If they want 3k to replace exhaust manifolds...... they're trying to rip you off.
Even at warranty time (about 10 hours) and 100 something an hour shop rate, it should be under 2k.
Unless you have the one with the cats integrated, then they get exspensive. But the ones with the cats in them usually don't leak either.
Shop around... you'll likely find someone to do it for MUCH less.
But if you think you're better off with another brand.... I'd wish you the best of luck, and when you come back to Toyota, I'd say "I told you so".
Rix is offline   Reply With QuoteReply With Quote
Old 07-28-2011, 08:16 PM #7
Yea I'll have to check around . They said the manafolds were $750 a piece and heat shields were $70 a piece , plus gaskets ect., ect. . And they quoted 11.5 hrs labor .
Old 08-02-2011, 10:23 AM #8
cruzmissile cruzmissile is offline
cruzmissile is an unknown quantity at this point
In the middle of it.
I have the right side wheel off, the truck on stands and penetrating oil already working....
I started hearing the ticking last year and it progressively got worse. Finally failed inspection and that is why I now have to do it. The dealer wanted 2k just for the right side manifold repair......i'll have raw bloody knuckles from working in that tight space before ever give into that!!
I'll keep you posted as to what I REALLY found because I'm guessing they only guessed themselves when they said it was the manifold. I'm still hoping for just a leaky gasket.
BTW, my 05 V8 only has 76k miles on it!!
cruzmissile is offline   Reply With QuoteReply With Quote
Old 08-02-2011, 11:25 AM #9
Rix's Avatar
Rix Rix is offline
Rix Rix is offline
Rix's Avatar
The manifolds are usually cracked where they are bent to form the flange.
I've yet to see one that is just the gasket. Now I have seen someone tighten one of the nuts with the flange not seated correctly, and bend the new manifold.
Your best friends are a 14mm semi-deep u-joint socket, or a ujoint with a 14mm socket, and a long extension, and good ratchet.
You can sneak all the nuts out that way. You HAVE to be really carefull, and make wure the socket stays straight on the nut, though.
Old 08-02-2011, 12:18 PM #10
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
I had/have crack in my 2003 V8 manifold. It comes as one piece with the cat. Last year I was also quoted over 1000$. I think it was more like 1500/1600$
I had lots of work done on my cars at a garage/muffler place around the corner. Got to be friendly with the owner as he wanted to start doing some offroading too but didn't know where the trails were....bingo........I did..... so we chatted a little more....
And....he offered to do the repair old school. He pulled it off, and welded shut the crack. Apparently that's how they did it in the old days and none of the young guns know to to do that, or want to do that yadayadayada...Anyway...
He also noticed that it had already been done before. My truck was second hand. So who knows.....
Anyways, it lasted about year. I hear it again now. But only when it starts up, and Ihear nothing on the inside while driving. But he did tell me it would get me by for about a year. Maybe this could be an alternative to hold off paying the 1500$ right away. This worked for me. No inspections to pass where I live. So can't say if it would pass or not. But noise is minimal.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 08-02-2011, 12:39 PM #11
Rix's Avatar
Rix Rix is offline
Rix Rix is offline
Rix's Avatar
If they don't have a check engine light or stored codes, it's just about guaranteed that it'll pass tailpipe/emissions inspections.
Old 08-02-2011, 03:57 PM #12
Ok good. Check engine did not light up for me for that. But I did have a bad seal where the end of the piping and cat meet the second exhaust pipe that takes the exhaust to the back to the muffler is bolted. That seal was leaking exhaust, and taking in air, and the sensor that is there was not getting the proper reading so it gave me a check engine. Cost me only just a few dollars for that seal and new bolts. While at it, I had all those seals and bolts changed. Check engine light was then gone.
Toyota wanted to change the manifod, and the sensor and change exhaust pipe because of my CEL.
When the Check Engine throws a code....it is not always saying, "hey i'm a bad sensor, change me, and everything will be better" Sometimes it is just saying " hey I'm a sensor, and I'm not sensing what I should be sensing, adjustment needed" in other words, the sensor is doing what it is suppossed to be doing.
Old 08-02-2011, 04:08 PM #13
Rix's Avatar
Rix Rix is offline
Rix Rix is offline
Rix's Avatar
That's it exactly.
A sensor is seeing something out of it's parameter limits, or an ecu is seeing sensor out of IT'S parameter limits.
Old 08-02-2011, 08:20 PM #14
Anyone know the torque value for the 8 manifold nuts? I need a device manual, but am still looking for a cheap download.
Old 08-03-2011, 04:05 PM #15
Rix's Avatar
Rix Rix is offline
Rix Rix is offline
Rix's Avatar
2005 v8 says 33 ft-lbs.
