Old 02-08-2010, 01:05 PM #1
mudd mudd is offline
mudd is on a distinguished road
12V outlets
My o7 SR5 V-6 has two 12 volt power outlets. One is in front console the other in rear cargo area. Neither works. I have checked and replaced the cigarette and the acc fuses. Neither plug works. I read the owners manual and no other system has an issue which leads me to believe there must be an in line fuse somewhere. Where should I look for it or any other suggestions.
Thanks
Mudd
mudd is offline   Reply With QuoteReply With Quote
Old 02-08-2010, 05:44 PM #2
kbeck2342 kbeck2342 is offline
kbeck2342 is on a distinguished road
you have to push the button to the left of the steering wheel to have these plugs turned on. the ignition has to be atleast on to the acc setting for them to have power from the battery
2008 Urban Runner 4x4 V6 - Nitto Terra Grapplers 265/70/17 on AR black rims. Airlift 1000 air bags w/compressor and gauge mounted in middle console. FJ springs w/5100's at 1.75 to perfectly level front to back. Tranny cooler, hidden hitch, limo tint...tom tom is on the chopping block next.
kbeck2342 is offline   Reply With QuoteReply With Quote
Old 02-08-2010, 07:02 PM #3
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Thanks
Mudd
These don't have an ON button. The ignition must be on. If that doesn't work check the 15A PWR OUTLET fuse (inside fuse box at driver's knee.)
Follow the links in my signature if you want to do a simple mod to have them on all the time.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 02-11-2010, 10:14 AM #4
LL21 LL21 is offline
LL21 is an unknown quantity at this point
I have an 07 SR5 and I've had the same problem with the power outlets. I've replaced the fuse 3 times. It always blows when I connect a cell phone charger after charging the cell phone a few times. I don't know if the charger is the problem causing the blown fuse or if their is something wrong with the circuit. The fuse box is below the steering wheel and to the left of it.
Does anyone know what to do to permanently fix this issue?
LL21 is offline   Reply With QuoteReply With Quote
Old 02-12-2010, 08:14 PM #5
ALLEGRO's Avatar
ALLEGRO ALLEGRO is offline
ALLEGRO is on a distinguished road
ALLEGRO's Avatar
I have never blown a fuse, and sometimes I power my phone, XM and Garmin at the same time.
I would check my charger, maybe even borrow a similar model and see what you find.
2007 Driftwood Pearl Limited
ALLEGRO is offline   Reply With QuoteReply With Quote
Old 02-13-2010, 07:21 AM #6
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
Ditto, I run my Garmin in it all the time, and when necessary I use a two way adapter to also power the cell phone charger at the same time. Never had a problem with a fuse, so far.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
