02-17-2010, 07:51 PM
Starting issue
Hey Yall,
I have a little problem with my 2003 V8 4wd lmtd. When I start it I sporadically get no sound a pause and then it starts. I replaced the battery a few weeks ago and thought that did the trick, but it did it again a few days later. I then took it to my mechanic who thought it was the starter but was not sure enough for me spend $640.00 to replace it without being sure of the diagnosis. Now I'm waiting to see if it completely stops when I need it most.
Any help or insite would be appreciated.
Love my Toy,
Steve
02-17-2010, 08:01 PM
Banned
Banned
Welcome aboard! Did you replace your spark plugs ever?
02-17-2010, 08:41 PM
Super Moderator
Super Moderator
You might be due for a starter. If the battery is good, all the cables tight and clean, you might have a failing starter solenoid. The solenoid is attached to the starter and is part of getting a new starter.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
02-17-2010, 08:58 PM
I haven't changed the plugs yet, just turned 80k, probably not a bad idea though.
02-17-2010, 08:59 PM
Is $640.00 a fair price, I suppose most of it is labor.
02-17-2010, 09:03 PM
Banned
Banned
Not for spark plugs.
02-17-2010, 09:16 PM
The $640 is for a new starter quote.
02-17-2010, 11:12 PM
Super Moderator
Super Moderator
I looked at www.Partznet.com, the starter is expensive. That starter is fairly labor intensive to replace. The intake has to come off, you have to buy coolant and some misc gaskets. I am sure any shop that specializes in Toyotas could do it for a little less but it's a big job.
Chris
02-18-2010, 09:10 AM
Thanks Chris. I trust my mechanic, it just seemed a little high especially without knowing for sure it was the starter.
Steve
02-18-2010, 07:05 PM
Steve
That sounds like one of the classic symptoms with starter contacts (I believe all 3 rd gen 4Runner had that after 100K). It was $5.00 parts and 3 hours labor DYI.
So if you going to your mechanic I would ask him to check starter contacts first… at least you will not have to pay for new starter just a labor.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
