Old 03-10-2010, 08:04 AM #16
Jed Jed is offline
Banned
Jed is on a distinguished road
Jed Jed is offline
Banned
BTW, the very first thing any competent mechanic will do when diagnosing a potential electrical problem is to check the battery. The strangest things can happen when you have a week or internally shorted battery. All you really have to do is check the voltage to make sure it is fully charged, and then use a load tester to check the amperage of the battery.
Jed is offline   Reply With QuoteReply With Quote
Old 03-11-2010, 10:04 PM #17
morphius909 morphius909 is offline
morphius909 is on a distinguished road
I can floor our rig with the VSC never coming on.
That's just wierd. there are alot of factors associated with VSC. Pitch, Yaw, Slippage, Spin (help me out here guys). Maybe something needs to be reset or recalibrated.
Regardless, take the vehicle in asap. 2008 = still under warranty.
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
morphius909 is offline   Reply With QuoteReply With Quote
Old 03-11-2010, 10:36 PM #18
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Yep... Another one is steering wheel angle.
If the hit on the right front was enough to knock the alignment out and the wheel isn't straight now that may do it.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 01-10-2011, 06:53 PM #19
MICA4R's Avatar
MICA4R MICA4R is offline
MICA4R is on a distinguished road
MICA4R's Avatar
After a lot of research and prying with Toyota Truck Division (HINO MOTORS) in Japan: Apparently there was a bad batch of sensors for the wheelspin that went out from the supplier to Toyota, they said that only 20% of them went out and that the on board computer has multiple redundancy checks so that even if a sensor malfunctions it would not trigger the VSC to activate. HOWEVER!, they would not comment on whether the on board computer would be smart enough to recognize and prevent VSC 100% of the time that there is sensor error, so there you have it! The culprit is unveiled.
2008 SE 4.0 4WD 5100's
MICA4R is offline   Reply With QuoteReply With Quote
Old 01-23-2016, 02:52 PM #20
Pappion Pappion is offline
Pappion is on a distinguished road
Steering Rack caused VSC activation
My RAV4 steering rack had got mushy and weak after 150,000 miles. Not by much, but I guess "over steered" to compensate. Also noticed the road tilt required more steering correction.
So, the YAW inertia sensors pointed one way and the Steering was pointed farther. The computer thought it was in a skid. Happened left or right, and over 45MPH (Yaw sensors accuracy have a minimum speed?). Somewhat random.
A dealer diagnosed the steering rack, but did not duplicate VSC alarms. My shop said that steering rack replacement are common. So, I had them fix the obvious problem 1st, and the VSC never came back.
Pappion is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 04:42 PM #21
Cheesyb Cheesyb is offline
Cheesyb is on a distinguished road
I know a log shot on what seems to be like a dead thread,
Have we ever figured this out, I just got one and its doing it. I am too new to post a new thread on here so I am trying to figure it out the old fashion way.
Cheesyb is offline   Reply With QuoteReply With Quote
