Old 04-24-2017, 07:03 PM #31
Pgshields Pgshields is offline
Pgshields is on a distinguished road
Same thing happen with me. After getting in my car a few times with a mini pond in the drivers side floor board I found the problem
Pgshields is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 12:27 AM #32
adrian_cast adrian_cast is offline
adrian_cast is on a distinguished road
Having the same issue w my wife’s 2004 4runner. Always parked in the garage except for one day it rains and this problem happened. Radio/clocked stayed on. Battery drained overnight so i pulled the no.2 radio fuse. Display works but no volume. Going to look at that harness tomorrow.
adrian_cast is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 05:15 PM #33
Trying to uploads pictures but keeps saying “failed” when I’m uploading.
Edit: if anyone wants to see some pictures just message me with your number and I’ll send them.
Old 01-19-2019, 10:13 PM #34
Originally Posted by rjptnman View Post
Had exact same issue as Black Rock Fab. Had the front end on jack stands for one week while working on front end so car was tilted toward rear. Afterward the radio and climate control back light would not turn off with ignition. Battery drain when checked between negative battery post and loose negative battery cable was about 3.2A. With radio #2 fuse pulled the amp draw reduced to 20mA. After reading this thread I checked the amp area for water. Found right rear cargo floor under felt mat soaked. No dampness around amp, sub woofer, or sunroof drain tube. Checked the wiring harness connector wrapped in tape per Black Rock Fab. Junction was filled with water and corroded exactly as shown in his photos. Cleaned the connector and routed it 180 degrees so water could not drain into it. All is well for now. Would have taken much much longer to find this without this forum. You guys rock!
Was your junction connector cracked?
Old 02-16-2019, 12:28 PM #35
Cwood27 Cwood27 is offline
Cwood27 is on a distinguished road
Where was the junction box that collected water? My 4runner is doing the exact same thing
Cwood27 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 08:22 PM #36
neff2468 neff2468 is offline
neff2468 is on a distinguished road
Im having the same issue, for a v8 2004 T4R. Its driving me crazy!!!!
neff2468 is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 04:07 PM #37
lancaja lancaja is offline
lancaja is on a distinguished road
Just wanted to thank you all. This post just saved me a week or two worth of afternoon troubleshooting. I did not have rust yet, but had some moldy looking funk growing in the back of the blue cap. Cleaned it, rerouted the drain hose a little and it seems to be fixed.
lancaja is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 12:24 PM #38
chrisonfiya's Avatar
chrisonfiya chrisonfiya is offline
chrisonfiya is on a distinguished road
have you checked the corresponding fuses?
chrisonfiya is offline   Reply With QuoteReply With Quote
