UPDATE: Rattle, suspension related, I think..
THE BACKGROUND INFO:
So for the past couple of months I have been driving with a dead X-REAS shock and a wheel bearing that was going bad. Last week I dropped my truck off and had them put in regular shocks, a new CV shaft and boot and a new wheel bearing.
I picked the truck up today and as I was driving it I noticed a rattle. So I turned around and brought it back. I brought 3 separate mechanics out for drives and everyone could hear it and all agree its coming from the same area but no one could diagnosis the rattle. The X-REAS system is still in place and the mechanics made sure it wasn't one of the ends bouncing against the frame. I am dropping the truck off on Monday morning and they are going to comb through their work to find it but I was hoping for some possible ideas...
THE NOISE:
At any speed there is a rattle from the front passengers side. Going over bumps causes the noise to be louder. It sounds exactly like if you put a marble into a glass jar and rolled that jar around. (I even thought maybe the fog light fell into the glass housing and was rolling around) One mechanic described it as a washer fluttering loosely against metal.
WHAT WAS CHECKED:
All bolts and washers that connect to anything in that area
All glass housings and lights
Heat shields
Brass ends of the XREAS system
Caliper clips
Truck was put on a lift and parts were pulled, pushed, bumped and banged
DIAGNOSIS:
UPDATE: Cotter pin was loose and/or out and bouncing around on the hub. It was difficult to get the exact location since I picked it up after hours and the guy working the desk didn't work on my vehicle. Hopefully this helps anyone who may have this happen to them in the future!
