Old 10-22-2020, 03:56 PM #61
DavisTN's Avatar
DavisTN DavisTN is offline
Real Name: Chris
DavisTN is on a distinguished road
DavisTN's Avatar
Real Name: Chris
Originally Posted by agridi57 View Post
Did this feel/sound like an on/off engine cutoff type of vibration/sound? When I am driving on the highway i get this vibration like if I am constantly pushing and letting the gas go. Front wheel bearings were just replaced but noise is still there. I have a 2006 SR5 V6 FWD.
Over a year late, but yes. My vibration was generally only occurring at highway speeds of 55 MPH + and only occurred when letting off/coming back on to the gas pedal. It was mostly a felt vibration under foot, but it would occasionally be accompanied by some harmonics.
When I say "custom", I mean made from crap in my garage.
DavisTN is offline   Reply With QuoteReply With Quote
Old 12-16-2020, 01:59 AM #62
NerfRunner NerfRunner is offline
NerfRunner is on a distinguished road
5th Gen Harmonic Vibration
Ok, so I need some help.
I have a 2019 4Runner SR5P with 2” Icon Suspension, 17” SEMA rims and I just put on a new set of Falken Wildpeak A/T3W 275/70R17 C 114S.
Before I changed out the tires from Nitto Ridge Grappler 265/70R17 C 109Q’s, I had a hum that would start around 40mph up to 50mph. The hum was not associated with an out of balance (that I know of) or out of round tire, since I still get it with the new ones. The hum pulsates roughly once a second and is slow, if that makes sense. With the new tire, braking at 40+mph does increase the hum, but is not felt in the pedal, but is felt through the vehicle and steering wheel. The brakes have been check and are not warped. With both the old and new tires I get a noticeable shake in the steering wheel at around 60mph, and a more consistent hum that I think could be associated with the fact that the tires are new and are AT’s. I’m more concerned with the shake of the steering wheel over the amount of road noise.
My thinking is it could be an alignment issue (hopefully) or a bad wheel bearing. It being a “2” year old vehicle I’d hope it wasn’t a bearing.
I’m not using wheel spacers. My last shop visit I had the Toyota mechanics retighten to spec all the suspension hardware. The SEMA rims are also Toyota spec. I have not other major mods beyond a K&N intake (OEM intake box).
Thank you in advance for you thoughts.
NerfRunner is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 10:32 AM #63
Proyota's Avatar
Proyota Proyota is offline
Proyota is on a distinguished road
Proyota's Avatar
The vibration you're experiencing may be due to the needle bearing on the front differential on the driver's side CV Axle having too much play. East Coast Gear Supply has a solution. See the following thread in Tacoma World... Front Diff Vibes ECGS bushing fix. | Tacoma World
See also a couple of video's here on YouTube:
Toyota T8CS Bushing Solution - Part 1 - YouTube
Toyota T8CS Bushing Solution - Part 2 - YouTube
Proyota is offline   Reply With QuoteReply With Quote
Old 12-25-2020, 12:57 AM #64
It seems that this is indeed the cause which was confirmed by the head mechanic at the Toyota Dealership here. This type of vibration most likely can be confirmed by putting the vehicle into 4H at the confirmed speed at which the vibration is felt/heard. When the vehicle is in 4H the vibration will stop and will resume when taken out of 4H.
Thank you for the tip!
Steering Wheel Vibration at Highway Speed...revisited Thai Problems & Warranty Issues 74 12-18-2014 04:42 PM
Vibration Problems continue. graygo General Discussions 1 07-27-2010 08:01 PM
Vibration FIXED - hallelujah! 3+1Runner Classic T4Rs 0 05-07-2007 01:43 PM
Vibration update... jtb71 4th Gen T4Rs 9 03-12-2004 01:04 AM
Harmonic Droning Noise NoDak Problems & Warranty Issues 12 03-10-2004 12:54 AM
