10-11-2010, 11:26 AM
Not getting enough volts at the fuel pump......need help
Hey everyone,
Maybe you've heard this happen before, maybe you haven't..........anyways, I just bought this 1992 4runner, 5speed, V6 recently. The guy told me that there was a leak in the fuel line and that's why it wouldn't run (I could smell the gas). When I got it home and started looking into it the fuel lines where fine but the tank was leaking. I took the tank out and found the leak (small), while I had it out I checked the fuel pump to see if it was working (I hooked up some leads from a battery, fuel started flowing). I sent the tank in to get it fixed/sealed. I get the tank back in and it just turns over.........no fuel. Pull the tank back out, leave the lines hooked up and hooked it up to a battery for constant power..........runs like a charm.
Now I take my volt meter to check for power from the wiring harness and I'm only getting 4.6 volts???????? WTF. I traced the wires to look for some brakes, nothing. I checked the relay under the hood (EFI relay), working good. There's full volts coming in and going out of the relay, as soon as I get inside the truck it's down to 4.6...........
I'm at a loss here, P L E A S E H E L P.
Thanks,
4r
10-11-2010, 04:52 PM
Super Moderator
Super Moderator
Bump/move
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
10-11-2010, 05:17 PM
I certainly am very little help at electrical - but I'm pretty sure the signal from the EFI relay then runs through a 15 amp fuse in the fuse box - correct? So are you getting the correct volts after the fuse block?
Carl Johansson
10-11-2010, 07:27 PM
Not sure......I'll check tomorrow. The fuse is OK.
10-14-2010, 09:16 AM
Real Name: Brad
Real Name: Brad
How's it going?
So do you have the wiring diagrams for your runner? That would be the first place to start for me - download everything you can. There's a Toyota wesite where you can download all that info I'll try to get it for you if you want it.
Anyway, I would work my way from the relay to the back checking voltage, seeing if there's a drop, & inspecting for corrosion. Also check for continuity, and the resistance of the wire between the relay & fuel pump. There may only be two or three junction breaks in-between the relay and the pump, but disconnect at each point and check from there (for voltage, corrosion, continuity, etc).
Obviously there's got to be corrosion or a damaged wire somewhere in there. Unless there's a resistor used (There's a fuel pump resistor on my 4th gen), you should have full power at the pump. Once again, you are guessing without diagrams.
Good luck!
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
10-16-2010, 08:23 AM
if you could send me those diagrams that would be very helpfull.........thanks.
10-17-2010, 06:32 AM
Real Name: Brad
Real Name: Brad
Sorry, I should have been clearer. What I meant was I could get you the website to download the diagrams. Unfortunately it's not free... But definitely helps. A 2 day subscription is $15. Month is $75. Used to be $10 & $50.
https://techinfo.toyota.com/techInfo....toyota.com%2F
Support our troops!
