Old 10-16-2010, 01:48 PM #1
wolfgang's Avatar
wolfgang wolfgang is offline
wolfgang is on a distinguished road
wolfgang's Avatar
Not level in rear - XREAS
The rear end of my '03 SE $L V6 with XREAS is not level from side to side in the rear. Difference in height to same point on fender well is 1.5" with passenger's side being higher. Front is same height side to side. I noticed this year plus ago when I had DunFlops replaced with Michelins at Costco. At first I thought they had put a different size tire on one side but all 265/65x17". Then I thought since it was on lift for so long perhaps the XREAS fluid needed time to compensate and would level out once driven a bit -- well that didn't happen. Checked XREAS supply tubes to shocks for XREAS and all are fine - no leaks or kinks. It's like the high side needs to be burped! Vehicle only has 45k miles - never wrecked or off road (I'm original owner and sole driver). Can I replace a single XREAS shock? Any trick so fluid doesn't pour out. All I can think is shock on high side is frozen in extended position???
'03 Black 4L V6 4x4 SE 4Runner/'03 Navy 4 cyl SE Camry/'05 Phantom Gray Corolla LE/'85 Rust-white 22RE Yota SR5 PU
'57 Black/Red 356 Porsche Speedster CMC Replica
MODS: Silverstars, WeatherTech mats/vent visors/Hood deflector, BORLA dual exhaust, K&N Filter Charger, VVT-I emblem, JDM tail lights, SS rear bumper step, Putco chrome mirror/door handles, Limited lighted running boards, 115V AC inverter, Rosta seat heaters, HomeLink, Michelin CrossTerrains
wolfgang is offline   Reply With QuoteReply With Quote
Old 10-17-2010, 01:50 PM #2
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
The X-REAS shock can be removed. There's a disconnection point further away from the shock which will keep fluid loss at a minimum.
Don't disconnect the line at the shock itself, that will cause fluid to leak.
http://www.toyota-4runner.org/attach...suspension.pdf
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 10-17-2010, 10:02 PM #3
wolfgang's Avatar
wolfgang's Avatar
Hummm - so it could be the center control absorber or a stuck check valve!
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
08 Limited both rear Xreas leaking at 14K bbumbles Problems & Warranty Issues 13 03-24-2010 02:30 PM
factory rear air lift solution good so far 4runnerforum 4th Gen T4Rs 2 12-04-2009 10:55 AM
Question for V8 owners with Rear Air Suspension AlexJet 4th Gen T4Rs 22 03-04-2006 11:06 AM
