Originally Posted by Uneek
Is the rear window fully closed? The wiper and defrost won't work if it's not fully closed.
At any point did you disconnect the battery? Is the auto up/down functionality of the rear window working? If you disconnected the battery and/or the auto function isn't working you need to normalize the window. To normalize the window, fully open the window and hold the down position for a few seconds; then close the window and hold the up position for a few seconds. Check to see if the auto up/down function is working. Now check the wiper.
thanks, Uneek. window was closed, but i hadn't normalized it after HID install. all is well. slightly embarrassing, but better here than in person at the dealership..
