Old 01-16-2011, 11:00 PM #1
U.G.N.'s Avatar
U.G.N. U.G.N. is offline
U.G.N. is on a distinguished road
U.G.N.'s Avatar
Question 1997 Limited V6 Underhood Howling Noise
Hi all,
I have got a howling noise since last September and need your help as Toyota dealership could not find out what is the cause of it. I have driven my vehicle for more than 6000 kms since I found out about the noise. I will try to describe it as much detailed as possible. The howling noise does not happen when the engine is cold (RPMs about 1100 or higher), when I just start the vehicle, I don't hear it. If I drive and the engine is warm, stop at a stop light, I could hear it with low RPMs (600 usually), it's the same monotonous noise like a flying bee. When I turn off the vehicle and start it again I hear the noise. It looks like the howling comes from the front (it's somewhere behind the driver's console in the middle) and it does not matter if the transmission is in Parking, Neutral or Driving position. The lower RPMs the louder howling noise. If I put engine above 1000 RPMs in Parking the noise disappears. Where could it come from? The dealership suggested change the whole transmission ($3800) or torque converter ($1100) but I believe the problem somewhere else. Thank you for your help!
U.G.N. is offline   Reply With QuoteReply With Quote
Old 01-21-2011, 09:53 AM #2
KB084RUNNER KB084RUNNER is offline
KB084RUNNER is on a distinguished road
Replace the transmission? Is the noise coming from the trans? If so try changing the trans atf first. How many miles on your 4R? Have you ever changed the trans oil?
2008 4Runner Limited 4.0L V6
KB084RUNNER is offline   Reply With QuoteReply With Quote
Old 01-21-2011, 02:01 PM #3
U.G.N.'s Avatar
U.G.N.'s Avatar
Toyota dealership told me noise was coming from the transmission but in my opinion it was coming from the engine.
ATF fluid was change several times in the last 3 years - May 2008, November 2008 (including the metal filter under the fluid tray), July 2010 and in October 2010 as well when a dealership mechanic removed the tray to examine it for debris. Everytime fluid was in good condition, no burning smell, good color, no metal debris on the bottom of the tray (Dealership mechanic confirmed it), it was perfect.
I have about 300,500 kms on it. I bought it when it had 234,000 kms 3 years ago.
Could it be water pump or steering wheel pump? Or timing belt? It's hard to tell exactly but I believe howling noise comes from the centre of the engine somewhere there.
2006 Lexus LX 470
2008 Toyota 4Runner Limited V8
TLCA# 26527
Old 01-23-2011, 10:48 AM #4
simmonsauto simmonsauto is offline
simmonsauto is on a distinguished road
Have the same problem in my wifes 98. its the pump in the trans. To lazy to rebuild it so its gonna be driven until its done. (which could be a long time)
simmonsauto is offline   Reply With QuoteReply With Quote
Old 02-05-2011, 12:10 AM #5
U.G.N.'s Avatar
U.G.N.'s Avatar
Is there a way to fix it without rebuilding or changing? Will ATF flush help? The one where it pushes old fluid with fresh through a machine?
I was listening to it and found that the noise changes tone (it's like if it would sing, from lower to higher tone). The pattern of the sound is the same, sometimes it gets louder.
What I also found that it does not necessary appear when I stop - it could disappear, I go for couple blocks, stop again and it reappears.
2006 Lexus LX 470
TLCA# 26527
Old 02-05-2011, 11:10 PM #6
Acidmeld's Avatar
Acidmeld Acidmeld is offline
Acidmeld is on a distinguished road
Acidmeld's Avatar
Try letting it get nice and hot and making the noise. Then shut it off and have someone start it while holding the cooling fan still. Ive heard that noise come from the fan clutch bearing before.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
Acidmeld is offline   Reply With QuoteReply With Quote
Old 10-16-2013, 11:06 AM #7
U.G.N.'s Avatar
U.G.N.'s Avatar
Smile
It's been a while since I logged in here. The problem was fixed in the fall of 2011. It turned out to be a faulty alternator. My battery did not charge enough and I had trouble starting the vehicle in cold days. As soon as I pointed out this issue to my dealership they found the alternator was faulty, replaced it and the howling noise disappeared and I never heard it again. I was lucky that did not do any costly repair with the trasmission.
2006 Lexus LX 470
TLCA# 26527
Old 10-16-2013, 01:53 PM #8
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
glad you got it fixed.
but, holy hell...talk about incompetent techs at the dealership. that should/would have been easy to locate.
but, to try to sell you a transmission, instead of FINDING the problem? that's ridiculous.
"sure, replace it, but it that's not the problem im not paying for the repair"
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
howling , idling , noise , parking , underhood
For SALE-2006 Limited V6 4Runner Jeffro4run Classifieds - buy & sell (no commercial ads please) 3 09-12-2010 01:15 PM
2003 Limited V6 Colorado Springs Weil186 Classifieds - buy & sell (no commercial ads please) 5 07-28-2010 12:45 PM
Howling noise carrollcy Problems & Warranty Issues 5 12-28-2007 07:55 PM
1997 4Runner Squeaky noise TBEST Problems & Warranty Issues 0 10-01-2006 08:59 PM
05 Limited Clicking noise - seat issue? cnims Problems & Warranty Issues 17 10-12-2005 11:31 AM
