Real Name: Jeffrey
Real Name: Jeffrey
Before you try replacing anything, seafoam the engine through the intake. You could just have some deposits in the engine, and it should clean it out. Its not a miracle fluid, but it works wonders when used right. I would suggest researching it, then getting the spray can seafoam. Its a little safer (mixes with air more), and you can hold the nozzle a little farther from the vacuum line. You'd need someone else to help you do this process, but its worth a shot. 8$ a can at walmart, and can do 2 or so treatments.
ASE Certified Automotive Technician
President: Storm Engineering, LLC
04' 4Runner 255 HP V6, Custom CA Intake, Spectre Filter, Custom Interior Light, General Grabbers 265/70/17, Catalytic converter deletes, Flowmaster High Flow Muffler, JBA Performance Headers, Jet Black Bull Bar, Rear Diff Breather Mod, 9006/9005 Silverstar Ultras in all * 160K Club *
