Old 02-16-2005, 12:46 PM #1
BattleWagon23 BattleWagon23 is offline
BattleWagon23 is an unknown quantity at this point
04 Rattle in the Rear
My first post here...I've read all the threads on the subject of rattles... checked out all the points but found out my rattle is caused by the small plastic pieces on the inside of the hatch... two pieces actually, the plastic around the pull down strap and the other is the square cover for an access point. Short of keeping duct tape around it, did anyone else deal with this problem?
BattleWagon23 is offline   Reply With QuoteReply With Quote
Old 02-16-2005, 03:04 PM #2
toyoboy toyoboy is offline
toyoboy is an unknown quantity at this point
Im a toyo tech and you would be the first
toyoboy is offline   Reply With QuoteReply With Quote
Old 02-16-2005, 11:41 PM #3
Cleric's Avatar
Cleric Cleric is offline
Cleric is on a distinguished road
Cleric's Avatar
Yes, these have been identified as a common source of rattles. I also found some minor ones on the doors of the rear interior quarterpanels. Get a powerful enough stereo system and you will find ALL of the potential rattles in this vehicles.
Do a search and you can find what others have done about the two you are having problems with. I just used some small foam adhesive strips, just inside of them. This is not visible, but insulates it enough to keep it to and eliminate the rattles.
-T
2003 SR5 V8 AWD - Imperial Jade Mica
3" Revtek Spacer Lift sitting on 285.60.18 Nitto Terra Grapplers
Kenwood 7120 DVD/Nav - K&N Intake - TRD Exhaust
Cleric is offline   Reply With QuoteReply With Quote
Old 02-17-2005, 01:37 PM #4
hre814 hre814 is offline
hre814 is an unknown quantity at this point
if you are sure you've isolated it to that exact area, i am not sure what is causing it. i had a passenger rear quarter panel rattle that started in my first month and it was the subwoofer in there that was either a little loose or rattled something loose. the first two times they blamed the rattle on the lift gate (after I told them i was hearing it over/near the rear passenger tire) and tried to fix it to no avail, and then finally a tech with a head on his shoulders did some more investigation and found the above problem. good luck.
------ Herman ---------
2004 V8 Limited (Titanium)
265/70/17 BFG AT KOs
HannaQuality Sliders
Cornfed Lift (Spacers; 3" F / 2" R)
hre814 is offline   Reply With QuoteReply With Quote
2000 4Runner Rear washer fluid line BROKEN needs repair skolinsk 3rd gen T4Rs 16 12-13-2017 05:44 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
Does Rear Locking differential Exist on '02 Sport? SaanichRunner 3rd gen T4Rs 33 03-14-2010 09:56 PM
Hummer H3 Thai Comparisons & Reviews 117 07-11-2008 11:06 PM
Need to find out rear diff ratio....help please? tfxpzeke01 3rd gen T4Rs 5 03-22-2008 11:25 PM
