Old 11-12-2018, 06:17 PM #1
ewingeric ewingeric is offline
Real Name: Eric Ewing
ewingeric is on a distinguished road
Rust on the undercarriage?
Hello friends!
First time poster, and hopefully soon to be first time 4Runner owner!
Looking at purchasing a 2002 4Runner, and have come across one that has an amazing interior, exterior and has low miles! Only concern is that it seems to have a good deal of rust on the undercarriage. Seller says that it's just surface rust (which there should be a remedy for?) but I don't know enough about the problems with rust to know if I should run from this.
Thoughts from a pro? Pictures attached.
Rust on the undercarriage?-used-2002-toyota-4runner-4drsr534lautomatic4wd-13377-18250927-43-800-jpg
Rust on the undercarriage?-used-2002-toyota-4runner-4drsr534lautomatic4wd-13377-18250927-44-800-jpg
Rust on the undercarriage?-used-2002-toyota-4runner-4drsr534lautomatic4wd-13377-18250927-45-800-jpg
Rust on the undercarriage?-used-2002-toyota-4runner-4drsr534lautomatic4wd-13377-18250927-46-800-jpg
ewingeric is offline   Reply With QuoteReply With Quote
Old 11-15-2018, 08:57 AM #2
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
Doesn't look too bad for a 2002 ... you should have seen my 2000! One thing I would recommend if/when you purchase put anti-seize any all bolts you remove.
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 12-03-2018, 01:58 PM #3
LinuxHack3r's Avatar
LinuxHack3r LinuxHack3r is offline
LinuxHack3r will become famous soon enough
I personally do not think it looks that bad, but I'm finding that when searching for these older vehicles rust is a bigger concern of mine that mileage.
LinuxHack3r is offline   Reply With QuoteReply With Quote
Old 12-03-2018, 01:59 PM #4
But, I also have to couple that with the fact that I am looking at 9-13 year old vehicles, so there is going to be some rust present. The question is, how much am I ok with?
Old 12-03-2018, 09:53 PM #5
ChaosStarter ChaosStarter is offline
ChaosStarter is on a distinguished road
That's nothing overall.
2005 4R V8 4x4 Limited - LEDs, FX-Rs, Gibson exhaust, TRD Red Front/Rear shocks, OME front springs, Toyotec rear springs, BF Goodrich 275/70/17 K02s, 1.25" Spidertrax. Front/Rear Polyurethane sway bar bushings, Total Chaos lower control arm alignment tabs. 150k miles and counting
2005 Prius - DD/Grocery getter. 250k miles and counting.
ChaosStarter is offline   Reply With QuoteReply With Quote
Old 12-20-2018, 08:56 PM #6
bsa70 bsa70 is offline
bsa70 is on a distinguished road
The rust around the spare tire is troubling. The other could be handled with a wire brush and paint. The other is very heavy pitting with flaking and onset rot. It looks like salt water rot to me. I would go from bumper to bumper with a high powered light and really look up around the spare tire, gas tank area. Many times salt water gets up in that area and is not washed out. Take your finger and feel inside the drain holes of the frame. If you feel rot walk away. If you see fresh paint-walk away.
It all boils down to $$$ for me. If it is an incredible deal. Its something you could live with for years to come and drive it as is. If you are paying top dollar-no way. Use it as a bargaining tool.
I have dealt quite a bit with Jeep Wranglers. Talking about rusted out frames! I have seen them so bad you could bust through the frame with a hammer. I've also seen folks spray expandable foam and paint covering stuff up.
bsa70 is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 04:20 PM #7
numbay numbay is offline
numbay will become famous soon enough
new 2020 with less than 1K miles even has rust starting
Noticed rust around transmission and xfer case.
Rust on the undercarriage?-rust-jpg  Rust on the undercarriage?-rust2-jpg
numbay is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 08:01 PM #8
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
These housings aren't aluminum on 5th gens?
Yea...that's your differential.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 11:15 AM #9
TrailGunner TrailGunner is offline
TrailGunner is on a distinguished road
OP, did you end up with it?
TrailGunner is offline   Reply With QuoteReply With Quote
Undercarriage Rust on T4R mikeikedc 4th Gen T4Rs 36 Today 10:03 AM
05 Undercarriage Rust 4runnah005 4th Gen T4Rs 43 01-06-2020 12:37 PM
Your opinions on this undercarriage rust please Reptile Christ 4th Gen T4Rs 2 04-04-2018 10:20 PM
Rust on frame and undercarriage eliask08 4th Gen T4Rs 5 08-02-2009 03:30 PM
