Old 04-24-2008, 10:17 AM #16
Apex Apex is offline
Apex is an unknown quantity at this point
Originally posted by sop
Thanks for the info. My 2007 SR5 V6 4WD goes in and out of 4WD mode with no problems. I switch it into 4WD(H) mode every so often, as per the manual's instructions, to keep the system properly lubricated.
I note you suggest leaving the vehicle in 4WD(H) mode permanently and I do have an observation or question and hope you or others can comment.
I notice that my 4R feels and sounds different when in 4WD(H) as opposed to 2WD. There is a very slight, nearly imperceptible, sensation that the engine is under greater load when in 4WD(H). I don't sense anything out-of-the-ordinary mechanically or in the operation of the engine....just a slightly reduced feeling of power and a very slightly increased mechanical sound when in 4WD(H) mode. This is noticeable on dry pavement when starting from a full stop, driving in a straight line and accelerating on the flats.
So far I've assumed this is normal with this vehicle and the feeling of greater engine loading and increased mechanical sensation is due to the additional moving parts when the 4WD system is engaged. However, I've not noticed this with other, less sophisticated 4WD systems I've previously owned. For the most part, they all seemed to have the same engine response, feel and sound when in either 2 or 4WD when on the flats, on smooth pavement and in a straight line.
I've not compared gas consumption in both modes on the 4R, so I cannot verify whether the sensation of increased load on the engine when in 4WD translates to greater fuel consumption.
Is this normal for the multi-mode 4WD system on the V6 4R? I have not yet done any serious four-wheeling since I bought the vehicle, and I'm wondering if these issues will subside when the 4WD system and mechanicals are more fully broken-in after extensive use?
Any thoughts?
I feel the added load too--just as you describe. It is turning the entire front drivetrain in 4WD so it seems perfectly normal to me.
Apex is offline   Reply With QuoteReply With Quote
Old 07-05-2008, 05:46 PM #17
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
To speed up locking the center diff, you may want to turn the steering wheel left or right (do NOT go left AND right). The gears for the front and rear driveshaft inside your transfer case has to line up for you to lock it. So, if you turn one way, then one gear will go slightly faster than the other gear, thus lining them up quicker. If you turn left and right repeatedly, then this may actually slow down the locking speed.
Remember, you need room to do this...so, don't go and run into a tree or something!
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 07-06-2008, 10:02 AM #18
sailor sailor is offline
sailor is an unknown quantity at this point
This is ridiculous (not you -- thanks for the info; Toyota is ridiculous) -- Toyota made such an bad product that (if one follows this kind of procedure) really puts drivers in danger.
sailor is offline   Reply With QuoteReply With Quote
Old 09-08-2008, 10:46 PM #19
BCKGUY BCKGUY is offline
BCKGUY is on a distinguished road
I've noticed that on my 04 SR5 a loud clunking sound sometimes occurs when switching from H2 to H4, but It's never not engaged....I've just always assumed that it's the gears in the differential lining up. I usually have to let my foot off the accelerator and slow down a bit, drive it a few feet and the light quits blinking and the system engages. Hope this is normal.....
2008 4Runner Sport Edition
2015 4Runner SR5
GO BUCKEYES!!
BCKGUY is offline   Reply With QuoteReply With Quote
Old 12-28-2009, 06:33 AM #20
Worlok Worlok is offline
Worlok is on a distinguished road
I hava an 06 4 Runner, and the darned light stays on and the 4WD does not engage. I have tried just about everything to get it to engage. What does it cost to get the vacuum actuator replaced? My 4 Runner is off warranty!
It is my wifes vehicle and it goes all summer without getting the 4WD engaged! So it sounds like the actuator has failed. Is the actuator on an 06 an electric motor, or a vacuum device!
Worlok is offline   Reply With QuoteReply With Quote
Old 12-28-2009, 05:47 PM #21
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
How many miles? The powertrain warranty lasts 60k. The actuator is electric. A few folks have had similar issues to yours.
Having said that I am confused, you say the light is on but the 4wd isn't working. Is the light on steady? How do you know it's not working?
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 05-24-2012, 11:00 PM #22
jmorabito25 jmorabito25 is offline
jmorabito25 is an unknown quantity at this point
I have the same issue. Did u ever figure out what was wrong?
jmorabito25 is offline   Reply With QuoteReply With Quote
Old 10-19-2012, 01:58 PM #23
PeteOB's Avatar
PeteOB PeteOB is offline
PeteOB is on a distinguished road
PeteOB's Avatar
In the User Manual it says to use the 4WD once a month consistently to keep it lubricated.
PeteOB is offline   Reply With QuoteReply With Quote
Old 10-23-2012, 11:55 AM #24
sr5owner?'s Avatar
sr5owner? sr5owner? is offline
sr5owner? is on a distinguished road
sr5owner?'s Avatar
I'm seeing mostly 4th gens with this issue. Do the 3rd gens have this problem? Curious because I'm looking for a 3rd gen.
sr5owner? is offline   Reply With QuoteReply With Quote
Old 01-01-2013, 02:56 PM #25
Mobius Mobius is offline
Mobius is on a distinguished road
Help
Guys,
My wife has a 2007 sr5 v6. I've tried a few times to engage 4hi, the green 4x4 indicator light flashes as well as an orange differential lock indicator. Both flash, and it doesn't feel like 4x4 is engaged. I've tried to do this from a rolling start, at a stop, from drive, from neutral, tried driving a few feet, tried reversing a few feet...nothing. Anyone know what I'm doing wrong?
Mobius is offline   Reply With QuoteReply With Quote
Old 01-16-2013, 11:10 AM #26
Knollie81 Knollie81 is offline
Knollie81 is on a distinguished road
Angry 4WD Now Only Engages/Disengages If I Go In Reverse
Yesterday the 4WD on my 2006 V6 4.0L started acting up and would not engage to 4H despite driving slow on a straight stretch of road for several miles. I then tried to turn it back to 2H while driving but the 4WD indicator light just kept blinking and wouldnt shut off.
...At this point I am fuming because just 2 years ago I had to have the actuator motor replaced for a small fee of $3000...the transmission shop told me the part that they replaced looked like it had been marked as if it had been replaced once before I bought it which would make it the 3rd actuator motor in the vehicle that has died.....GRRRRRRRR!!!!
After a 30 minute drive home, I tried shifting in reverse and only then did the 4WD indicator light stop blinking and finally shut off. It appears that my 4WD will now only engage and disengage if I stop and drive in reverse for a few feet. Just a few weeks ago I was able to shift it from 2H to 4H "on the fly" with no problems....any ideas why it wouldnt be able to do that now? Any ideas would be greatly appreciated as the warranty from the previous repair has just barely expired.
Knollie81 is offline   Reply With QuoteReply With Quote
Old 01-16-2013, 11:15 AM #27
The actuator motor that operates the transfer case may have gone bad and might need to be replaced...I speak from experience since the same thing happened to me a few years ago and cost me $3000 to fix. Most of the cost is in the labor since the whole thing will need to be disassembled and then reassembled.
I hope this isnt the case with you but figured it might be the cause. Recommend exploring every other possible causes as this can be one of the most expensive things to fix.
Old 01-16-2013, 12:06 PM #28
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
ENGAGing 4wd on the fly never works for me..the lights blink n blink..i simply put it in neutral ,the 4wd lights blinks..then i put it in drive and the blinking stops...and the 4wd sytem is engaged..all this takes les than 6secs
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 02-02-2013, 08:29 AM #29
Took the wife's '07 to the dealer yesterday. It was the accuator. Waiting on the part to come in. Luckily I bought the extended warranty or I'd be out $1900 plus rental fees.
Old 11-08-2015, 05:07 PM #30
TRevsRunner TRevsRunner is offline
TRevsRunner is on a distinguished road
I have one for you guys... I own an 02' sport edition and I experience some of the same issues. I can only engage my 4x4 when my truck is in neutral. The center diff locking mechanism will also only engage when in beau trial but does take a little longer. However I don't think that the system is operating correctly when the I take the VSC off. When I press that button the vehicle acts as if the front and the rear are not working together. Feels as if the front diff is binding up and causes the vehicle to slow down. Any suggestions?
TRevsRunner is offline   Reply With QuoteReply With Quote
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai General Discussions 57 09-01-2020 09:35 PM
Won't go into 4 wheel drive Torinate 3rd gen T4Rs 28 04-15-2019 05:43 PM
4wd engaging weirdly 01sr54x4 3rd gen T4Rs 3 08-19-2009 03:44 AM
Engaging 4wd H banker1 4th Gen T4Rs 7 02-05-2008 12:24 AM
