Old 02-01-2021, 05:40 PM #1
RagoFabrication's Avatar
RagoFabrication RagoFabrication is offline
Official Vendor
Real Name: Melissa Rago
RagoFabrication will become famous soon enough
Official Vendor
[b]airing up ☝ and down 👇[/b]
Is airing up really necessary?
The answer to this question is absolutely.
Whether you are on simple trails or intermediate ones, airing down your tires can significantly help your comfortability, traction, and prevent punctures.
Comfortability: If you trail ride, this should be one of the main reasons you air down your tires. When it comes to riding on rough terrain, not airing down your tires will give you a significant difference in ride comfortability and traction. Keeping your tires at standard PSI can not only give you an uncomfortable ride but can also knock you around and puncture your tires. Airing down your tires allows you to cover more surface area with the rubber of the tires and softening the blow by allowing your tire to absorb the tough impacts, rather than bounce off.
Traction: With Standard PSI, your tire will not be capable of gripping the terrain when you are trail riding. Lowering the PSI will allow your tire to deflate and more of your tire will be on the ground allowing your vehicle to gain more traction.
Preventing Punctures: Using normal PSI on the trails can cause punctures to your vehicle. Imagine a balloon that is filled completely and comes into contact with a sharp object. The balloon will instantly pop, right? Now imagine, if you were to deflate some of the balloon, and it comes into contact with that same object, it is less likely to pop. The same idea applies to lowering your tire PSI.
So now you decide, is airing up really necessary?
[b]airing up ☝ and down 👇[/b]-lowtirewifey_574x-jpg
Melissa Rago
www.ragofabrication.com
Rago Fabrication is a veteran family owned off-road product manufacturer. We design and fabricate quality off-road products right here in the USA. We offer vehicle specific LED brackets.Custom CAD design and CNC plasma cutting upon request. Follow Us on Instagram: @ragofabrication
RagoFabrication is offline   Reply With QuoteReply With Quote
airing , psi , tire , tires , traction
HTML code is Off
airing down 04run&gun 4th Gen T4Rs 4 12-07-2014 06:49 PM
Method for airing down? ShooterMcGavin 3rd gen T4Rs 21 02-10-2014 08:37 PM
Airing Down help... Overland Warehouse Off-Roading 5 12-06-2011 03:08 PM
CO2 for airing up BenSD 4th Gen T4Rs 1 03-11-2008 09:29 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
