Old 09-22-2016, 01:54 PM #31
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
i want to have it checked out, have my mechanic give it a good once-over and let me know what needs to be done. spark plugs, fluids, etc. it was regularly dealer-serviced over the years, but nothing major other than scheduled services. the previous owners said he never used the 4wd, so i want to have all those fluids drained and replaced, which may be something i can do myself with the help of a mechanically inclined FJ80 owner buddy of mine. there are some other issues that need addressing...
my tailpipe has come out of the seat clamp and i think the exhaust may be bent where it is resting on the frame. not only does it look slightly kinked/bent, i can't just lift it up and pop it back in. there's a little rod on top of the resonator that pops in to the rubber sway clamp, and it just won't reach, leading me to think the pipe may be bent.
my CV axle is leaking (looks to be spewing) chunky bluish-gray fluid. at first i thought it might be coming from the XREAS, but after reading a couple other threads and looking at a proper CV vs. mine, i think it is the CV.
these are both parts i was hoping could either be repaired as they are or taken off a part-out and installed on mine. i hate paying out the nose for new items and i'm pretty sure both of these things can be reused from a salvaged runner, which seem to be plentiful on socal craigslists.
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 09-22-2016, 02:56 PM #32
mwray8909's Avatar
mwray8909 mwray8909 is offline
Real Name: matt
mwray8909 is on a distinguished road
mwray8909's Avatar
Real Name: matt
It is bent I'd say. It looks like it got backed into something and pushed backwards. A rubber mallet my be able to help that but it'll take some work. And i would suggest just getting new CV boots if possible. The actual joint itself may be just fine
Edit: the boot looks fine just clean the area well, grease it, and put a new clamp on it. (Looks like it's just lost the clamp)
Sent from my SAMSUNG-SM-G890A using Tapatalk
15 Super white TEP- SR5 hood swap/ Discoverer ATP/ 24" custom mount light bar/ lamin-x yellow fogs/ cobra CB with K40 magnet mount antenna/ 2.5" 5100/ lots of plastidip/... It really never ends
mwray8909 is offline   Reply With QuoteReply With Quote
Old 09-22-2016, 03:46 PM #33
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
this place sounds perfect. do you know if he works weekends? i live in costa mesa and work in HB, MV is hard for me to get to during the week.
You could arrange for a saturday drop off or pickup, though his work is primarily on the weekdays
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 09-25-2016, 11:00 AM #34
Grey-Rhino Grey-Rhino is offline
Grey-Rhino is on a distinguished road
For sure thr boot is torn and the inside boot grease is grayish color, just did mine the other day.
Grey-Rhino is offline   Reply With QuoteReply With Quote
Old 09-25-2016, 12:27 PM #35
grave's Avatar
grave's Avatar
How do you figure the boot is torn from that photo?
pet every dog
Old 09-25-2016, 01:04 PM #36
mwray8909's Avatar
Real Name: matt
mwray8909's Avatar
Real Name: matt
To me it doesn't look torn.
Old 09-25-2016, 05:27 PM #37
The front part is where the clam goes on, it happened the same way on mine and I just replaced it the other day, took me about 45 mins.
Old 09-25-2016, 05:31 PM #38
Get a new cv axle to put on, then buy a new set of boots then you have an extra axle, just in case. They are the same for left and right.
Old 09-25-2016, 05:38 PM #39
You can see clearly the front end of the boot and the clam still on it on the right side of the tear.
Old 09-25-2016, 05:57 PM #40
As far as the exhaust, I would get an easy come-along and try to pull it out slowly. If you mess it up just do the sideway exhaust.
For the axle, if you have access to a lift or a big enough jack, ( I don't trust those bottle jack ) jack stand and tools you can do it yourself and save some money, the axle is about $100 or less and have lifetime guarantee. Just my 2c.
Oh I forgot about the front diff oil will leak out, I did change the front, transfer case, and rear diff 2. A little less than 7qts of 75w-90 oil.
Old 09-25-2016, 06:21 PM #41
This is when I put on the icons and found the busted boot.
SoCal 4Runner Shop Thread-20160914_150106-jpg
Old 09-28-2016, 10:22 PM #42
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Any recommendations for HAM radio install?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 09-28-2016, 11:27 PM #43
mwray8909's Avatar
Real Name: matt
mwray8909's Avatar
Real Name: matt
Why not go with a handheld
Old 09-28-2016, 11:52 PM #44
grave's Avatar
grave's Avatar
What's the advantage of ham radio over cb?
pet every dog
Old 09-29-2016, 01:42 PM #45
sfvtrdpro's Avatar
sfvtrdpro sfvtrdpro is offline
sfvtrdpro is on a distinguished road
sfvtrdpro's Avatar
I didn't see any shops mentioned in SFV or L.A. for bumper installation? Anyone have any experience with shops in the greater Los Angeles area?
Thanks
2016 4Runner TRD Pro Quicksand RCI Sliders
sfvtrdpro is offline   Reply With QuoteReply With Quote
socal re-gearing shop? slimboiphat 3rd gen T4Rs 5 09-28-2015 12:12 PM
SoCal BS and Rant Thread 4Running Daily So Cal 431 03-11-2015 07:44 PM
Spectre600's Crazy Idea Thread 6: Satoshi With a Custom Shop Twist spectre6000 3rd gen T4Rs 2 10-22-2012 01:23 PM
Any shop recomendations in SOCAL? (626, 909, 714) ronnieROCKS General Discussions 1 06-06-2010 07:53 PM
