04-17-2019, 10:45 AM
#331
Real Name: Jay
Real Name: Jay
Looking for a shop for to get 4lo fixed. Preferably in the OC area. Any suggestions is appreciated!
04-17-2019, 04:09 PM
#332
Real Name: Danny
Real Name: Danny
Check out first post.... Great shop, very dedicated and experienced shop owner, in Toyotas. Honest but expensive. Dealer type pricing but you get a detailed and well done job the fist time. Give them a call for a quote
Originally Posted by ChildrenOfBodom
Japanese Car Specialties - (949) 583-0811
25672 Taladro Circle, Unit H
Mission Viejo, CA 92691[/B]
The owner of this shop, John, is a Toyota guru with 30 years experience. 4Runners are a daily presence at this shop, plus he owns/has owned several. John is a master of the art, an honest mechanic who explains his work in great detail and solely uses only OEM or better quality parts. In addition, he makes sure every nut, bolt, and clip is removed and reinstalled carefully. The prices are fair and the parts he uses are top notch. Rest assured, if John performs a job, he does it right.
His shop contains a vast variety of 4Runner parts and custom tools specifically tailored to Toyota trucks and 4Runners. I wouldn't doubt that he could build a 22RE or 5VZ with his eyes closed.
He can diagnose and repair mechanical and electrical issues, perform clutch jobs, engine work of any kind, manual transmission rebuilds, transfer cases, suspension, lockers and gears for your diffs, axle seals, air conditioning, interior, you name it.
His wife, Wendy, sets the appointments, so be sure to tell her that James from the 4Runner forum told you to call. They'll treat you right.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
05-02-2019, 01:30 PM
#333
Real Name: Nelson
Real Name: Nelson
I know most of you have 5th gens but would anyone know of a shop that can tune a SC'd 3rd gen with a 7th injector kit?
05-02-2019, 07:21 PM
#334
I don't know of anyone but was looking into Magnuson. They have a dealer locator on the website. I bet that is a good place to start.
MAGNUSONPRODUCTS.COM
BTW how many miles on your rig when you installed the SC. I'm looking into doing it.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
05-07-2019, 06:32 PM
#335
Prime 4Runner Mechanics Thread in Los Angeles
Looking for some pointers on the best 4runner mechanics (by specialty) in the Los Angeles area. I'll start.
Silverlake Automotive (general maintenance)
Speedo Tech Whittier (speedo work)
Specifically, I am looking for someone to help with some body work and electronics work.
05-07-2019, 07:38 PM
#336
Moderator
Real Name: James
Moderator
Real Name: James
Request moved to SoCal shop thread
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
05-12-2019, 05:47 PM
#337
Speedo Check Whittier (speedo work)
Bump on this question. Echo park area. Looking for a reliable, affordable specialized 4runner or Japanese shop!
06-05-2019, 09:12 PM
#338
Can anyone recommend a muffler shop in or around the south bay (torrance/gardena) will venture out if needed.
I installed the Borla S Type but I think I need a resonator welded on.
i got the stuff
06-05-2019, 09:48 PM
#339
Is it that loud? Thought the S was suppose to be the quieter one of the Borla's.
06-05-2019, 11:48 PM
#340
it's not that loud like a flowmaster. But I can hear it in the rear cargo. I want to try to tone that down.
also its paired up with the URD y-pipe so maybe thats why it might be a bit louder?
i got the stuff
06-06-2019, 03:23 AM
#341
Aaahhh gotcha. Was looking into that y pipe as well.
06-06-2019, 11:57 AM
#342
Y-pipe with stock exhaust = same tone.
The car did feel better after i installed but that might be just me imagining? lol
i got the stuff
06-12-2019, 02:04 AM
#343
Originally Posted by 4runnerfiend
Had a request for pics on a different thread. Figure this is more of an appropriate thread to post. Truck Shop built sliders, they are awesome. I sent them some links to what I wanted, talked it over and they built and welded them on in a day... well actually it took two days but I had them do other work as well.
Here you go
@ Kamalani Mahie
what did it run you, if you don't mind me asking?
06-12-2019, 02:05 PM
#344
600.00 out the door. built and welded to the frame. they did a light coat of black also, but I had to re paint them right away.
James at the Truck shop is the man, I highly recommend them.
06-18-2019, 01:05 PM
#345
4WD transfer actuator case
New to the forum. I have an '09 4R, and it appears the transfer actuator to shift into 4WD is bad. I used to be able to just be able to tap on the case to get it to go into 4WD, but that no longer works.
I am located in San Diego (central San Diego). Anyone have suggestions on a shop to repair/replace the transfer actuator at a reasonable cost?
