09-30-2016, 03:11 PM
Sliders...are there real differences?
I'm looking to add rock sliders to the 4runner and have it narrowed down to RCI, metal-tech, and Shrockworks because they have 2 weeks or less turnaround time while others (Pelfreybilt and c4fab) had 6 week manufacturing time. Called cbi, but never heard back.
Prices are about the same and they're all powder coated. Are there real differences between these brands or is it just cosmetic?
Thanks
2016 4Runner TRD Pro Quicksand RCI Sliders
09-30-2016, 03:23 PM
Real Name: Mike or MAC
Pretty much cosmetics but mainly the type of material such as HREW or DOM tubing. DOM is a lot stronger. I went with Demello offroad in corona cause I could just pick it up. Been happy with it. You also have to decide if you want a hybrid slider combined with square 2x2 or 2x4 main square tubing with round tubing steps or all round tubing. Also, weld on or bolt on. kick out or no kick out. I went with DO hybrid rock sliders bolt on with 4th gen and weld on with 3rd gen. Been happy with it.
09-30-2016, 03:35 PM
Thanks for the info.
I'm looking at bolt on's with kick out.
Didn't know about HREW/DOM tubing and 2x2 or 2x4. I think most were 2x2. Didn't realize there were other options. I think one manufacturer said their sliders were originally meant for 6,500 lb Land Cruisers and can be used to lift the truck. I figured that was plenty strong enough.
Just goes to show you don't know how little you know until you start learning about it.
09-30-2016, 03:41 PM
Real Name: matt
Real Name: matt
Also look at BAMF or relentless sliders.
Sent from my SAMSUNG-SM-G890A using Tapatalk
15 Super white TEP- SR5 hood swap/ Discoverer ATP/ 24" custom mount light bar/ lamin-x yellow fogs/ cobra CB with K40 magnet mount antenna/ 2.5" 5100/ lots of plastidip/... It really never ends
09-30-2016, 03:45 PM
I started the same as you. I was actually gonna go with white knuckle offroad but like you said the turn around was lengthy hence DO sliders. They're all pretty much good products. I would narrow it down to kick outs & install type (you already decided) and type of tubing. Good luck!
09-30-2016, 03:55 PM
Not sure if it's dated, but 12 weeks turnaround for both.
RS does have some nice bumpers though.
09-30-2016, 03:57 PM
Real Name: Steven
Real Name: Steven
Basically all the same. DOM is stronger but if you aren't going to be bashing them super hard all the time, then HREW will be fine. I built mine with HREW because I had the material already and they have a couple small dings on the bottom but that's it and from pretty hard impacts. They are all basically the same. Just look for the ones that have frame plates and gussets. Idk if any come without those but they are a must
09-30-2016, 04:19 PM
Good to know, thanks.
09-30-2016, 04:47 PM
n00b question... what's the difference between rock sliders and the round running boards that came on my sport? material? durability? placement?
pet every dog
09-30-2016, 04:48 PM
Real Name: matt
Real Name: matt
Slider are stronger and used to protect the body.
09-30-2016, 04:49 PM
Real Name: matt
Real Name: matt
They others are a weaker construction and are meant to be only a atep
09-30-2016, 05:46 PM
And can you use sliders as jacking point, if need be?
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
09-30-2016, 06:02 PM
Real Name: Steven
Real Name: Steven
Yes! If they are built well. I've used mine plenty of times for repairs and to get unstuck.
09-30-2016, 07:23 PM
Real Name: Danny
Real Name: Danny
Yes. I've used mine twice now on the sliders, but you have to be ridiculously careful because a hi-lift can easily slip off a slider. Also had that happen once because I was jacking up the rear and the front tire moved just enough. Resulted in some door damage.
10-01-2016, 01:59 AM
Real Name: Chris
Real Name: Chris
Running boards attach to the sheet metal of the vehicle. If you were to hit them with a rock they would bend and likely also bend the rocker panel. When you get home you look under your vehicle and go oh F#%$%
Rock sliders are bolted or welded to the frame. If you were to hit them with a rock you would here a loud bang and some scraping noises. When you get home and look under your vehicle you decide if you want to touch it up with a little spray paint.
"I hope yours took a bath once in a while, kid. This guy's armor smells like he lived in it."
―Han Solo to Luke Skywalker, while donning TK-422's armor.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
