Old 10-30-2019, 10:55 PM #1
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Rear door grommet part numbers?
So I was running new speaker wire to my amplifier in my 2007, and when I got to the rear doors, I noticed that the rubber grommets are totally trash. They are all cracked and falling apart, so I did my best not to destroy them TOO MUCH getting my wire thru, finished everything up and put some diy loom cover over everything. I would like to replace the grommets, however I can't seem to locate a part number anywhere. Has anyone else run into this situation? Were you able to replace the grommets? Did you find an alternative? Everything I've turned up in search so far only references them as part of a write up, nothing about part numbers or replacement. Any insight would be helpful.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 10:37 AM #2
Oneluv13T4R's Avatar
Oneluv13T4R Oneluv13T4R is offline
Real Name: Miah
Oneluv13T4R will become famous soon enough
Real Name: Miah
I have some if you need them ....
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
Oneluv13T4R is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 10:44 AM #3
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Yes! I am still looking
Old 11-07-2019, 07:04 PM #4
DeathMetalTony's Avatar
DeathMetalTony DeathMetalTony is offline
Real Name: Tony
DeathMetalTony is on a distinguished road
Real Name: Tony
Do you have an image where this grommet you speak of goes?
Instagram @BigHead_805
Toyota Parts @ South Bay Toyota
2007 GX470
DeathMetalTony is offline   Reply With QuoteReply With Quote
grommets , part , rear , replace , wire
Blend door actuators part numbers firefoxed 4th Gen T4Rs 0 07-16-2019 12:36 PM
REAR Brake Part numbers needed tb-av 5th gen T4Rs 3 02-07-2019 09:56 PM
FJ Rear Spring Part Numbers Brilliant 4th Gen T4Rs 3 11-11-2013 11:09 PM
OE Rear Spring Part Numbers dml619 3rd gen T4Rs 0 12-27-2011 04:08 PM
door handles and roof racks part numbers jayhat 5th gen T4Rs 7 07-18-2010 03:11 AM
