01-07-2019, 09:05 PM
Real Name: Danny
Real Name: Danny
Any CB epxerts?
Anyone here know a lot about CB's thats willing to help? I have been trying to troubleshoot mine for over a year with not a lot of luck. I believe something is shorting out my CB signal but can't confirm... Have been to HRO a few times and they have helped me test and purchase new equipment and still no luck.
many thanks
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
01-07-2019, 11:32 PM
Real Name: Elliott
Real Name: Elliott
many thanks
What makes you think it's shorting out?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
01-08-2019, 12:56 AM
Very common for people to forget to use the nylon washers. When they do use the nylon washers it's typically in the wrong spot. Simple magnet mount antennas usually produce really low SWR readings. However , mag mount can scratch and/or induce rust.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
01-08-2019, 12:59 AM
Have you thought about switching to ham?
01-08-2019, 01:30 AM
Real Name: Elliott
Real Name: Elliott
Agreed. CQ
01-08-2019, 02:19 AM
Real Name: Danny
Real Name: Danny
I blew my first unit this way actually but not having the washer placed the right way. So i replaced it and I'm not hearing as clearly again. So not sure if this one shorted out as well.
I do have ham radio, I like to have both in an emergency.
Edit - thanks for the input.
Dual Battery Thread
01-08-2019, 09:21 AM
Oh God here we go. That didn't take long
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
01-08-2019, 10:14 AM
I did not know this. I just happen to have my CB antenna mount off and realized I have the washer in the wrong spot. Maybe this is why I get shitty signal.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
01-08-2019, 01:18 PM
Real Name: Danny
Real Name: Danny
That will also fry your radio.. thats what I did to my first one. On that note, anyone know how to unfry radios?
Dual Battery Thread
01-08-2019, 01:53 PM
Well shit. How do you know if its fried? I can still recive and transmit, there is just alot of static most of the time.
01-08-2019, 03:28 PM
many thanks
far from an expert, but have been using one for many years.
what exact issue are you having?
and, have you ever set the SWR's with a quality meter, not a built-into-the-unit meter?
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
01-08-2019, 06:36 PM
Real Name: Danny
Real Name: Danny
You literally have to take out the main unit and have it tested for how much wattage its outputting. Mine was putting out milli watts and its capacity is 5 watts... I just took my new one back in and tested it again to make sure i didnt blow the second one...
Pics:
without any output:
With output:
I'm not an expert but thats what Bob at HRO helped me with.
My older radio wasn't outputting much, my audio was coming in very faint. SO you will transmit and receive but with .5% of the power.
Hope this helps
Dual Battery Thread
01-08-2019, 08:07 PM
Real Name: Evan
Real Name: Evan
Mine was doing that at one point too. I have my cb radio mounted in the ashtray spot, and I had it tucked back enough that even with a 90 degree coax fitting it was rubbing the a/c behind the dash and over time loosened the cable and it did what you’re describing. I know it’s an obvious thing, but it’s worth double checking. Those connections need to be really tight to work right.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
01-08-2019, 08:41 PM
Real Name: Danny
Real Name: Danny
Checked SWR yesterday. Maybe it's just the nature of CB.
The issue is I can't get more than a mile on my CB when testing it with HRO. In the city that is. Maybe thats normal but I expect at least a couple of miles.
Also, even with the squelch all the way up (or down? i can't remember) i still hear a loud squelch at the end of the transmission.
Dual Battery Thread
01-09-2019, 01:26 AM
What was your SWR readings? Be sure to close the hood and all doors.
Some vehicles need the extra wire off the antenna. Others don't. Not all antennas have the extra wire. Is the antenna mounted to the front or rear of the vehicle?
Some have mentioned Ham radio. Ham is usually a better option. Where I live, the logging companies use CB. CB is a necessity. I also have a Ham license and cell phone booster. On the freeway I typically turn off CB because of the language. While I was in the Navy, my wife and daughter were not.
