09-28-2020, 02:48 PM
A day trip on the Mojave trail?
Hi gangters
Anyone know if the trail can be done as a day trip? I've seen lots of multi-day trip through there. I just wanna get out of OC for a day. Thinking of leaving in the middle of the night/late morning, be in that area by breakfast time, and taking in an easy trail.
Is it mostly 1 way? Or can I drive a few hours in, turn around, and come back same way I came in?
Looks like it can be done on 2wd mostly huh?
2017/SR5
6112/5100/OME/Camburg/MethodNV305/285/70/17
09-28-2020, 04:02 PM
You wouldn’t be able to do the entire thing but you could definitely do a portion of it in 1 day. There are a few paved roads that cross Mojave Rd that make good start and finish points for day trips, portioning the entire trail into 3 sections. You could easily do the western-most section as a (long) day trip from OC.
And yes, it can be done in 2 wheel drive, although I’d still suggest airing down.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
09-28-2020, 04:03 PM
Real Name: Danny
Real Name: Danny
For a day trip, I would recommend Anza Borrego. That's quite the drive to Mojave for one day, unless you are leaving at 5 am.
Its not one way, and there's a lot to explore, sand dunes, lava tubes etc...
It's taking me up to 8 hours in traffic. Probably 4 hours with not traffic and no stops. Anza is 2 hours.
Hope this helps
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
09-28-2020, 04:11 PM
Hope this helps
I thought about this too! I was thinking maybe I can do some of the Mojave trail, the spend a night at vegas or something.
But Anza Borrego sounds like a fantastic alternative.
I've seen some videos and I thought maybe I wouldn't be experienced enough to do the hard sections of AB. So maybe if I can do a little research and plan a day trip there to the mud caves, turn around, get some good tacos on the 78, and head back to OC.
Both sound like a plan. Oh also, yes, I don't mind leaving super early to get to Mojave!
2017/SR5
10-08-2020, 11:52 AM
Real Name: Danny
Real Name: Danny
There's plenty you can explore that's not hard.. - Sand Stone Canyon
- Wind Caves
- Mud Caves
- Badlands
First two are on the same route and my brother in law did them in a stock limited 4X4.
Maybe we'll set up a group run soon.
Dual Battery Thread
10-14-2020, 05:48 PM
Real Name: Kelly
Real Name: Kelly
When are you looking to go? I really want to check out AB and I have some other friends who would probably want to join.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
03-06-2021, 05:32 AM
[QUOTE=krhayes79;3554961]When are you looking to go? I really want to check out AB and I have some other friends who would probably want to join.[/QUOTE
@ DannyLlama
We should definitely setup a group run before it gets too hot out there. Lots of fun to be had in AB.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
03-06-2021, 05:34 AM
Hi gangters
What I've done a couple times is just head out to Afton Canyon and play around in the canyon crisscrossing the mojave river, check out the mud caves, and the mine outside the east end of the canyon. Beautiful place, lots of fun, and a good day trip. If you want to do a one-nighter you can camp at the mine site; it's pretty cool. And it's on BLM land so you can pop off a few rounds too.
03-06-2021, 08:33 AM
Is the water crossing on the west or east end?
I need to check it out some day as I live 20 miles from the east end.
03-08-2021, 05:27 PM
Real Name: Kelly
Real Name: Kelly
[QUOTE=Kamalani Mahie;3612518]
@ DannyLlama
When would be a good time? Is May too late?
03-09-2021, 01:37 AM
[QUOTE=krhayes79;3613439]
May would be alright I think. Typically May is high 80s.
03-09-2021, 01:14 PM
Real Name: Kelly
Real Name: Kelly
[QUOTE=Kamalani Mahie;3613623]
Will have to wait till it gets a little closer. Soccer is about to take over my weekends for the next two months.
Maybe the Memorial day but i am sure it will be packed out there.
03-09-2021, 01:59 PM
[QUOTE=krhayes79;3613731]
Ya it's already getting a bit crowded out in the desert on weekends. As the weather gets a little warmer it will only get more crowded the next couple months and then taper off into summer.
03-09-2021, 04:28 PM
Real Name: Kelly
Real Name: Kelly
[QUOTE=Kamalani Mahie;3613752]
I am actually on PTO the final week in March and might be able to do a day trip on 4/1 or 4/2
03-09-2021, 08:28 PM
[QUOTE=krhayes79;3613801]
I'll be out of town unfortunately at the in-laws that weekend haha
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
