Originally Posted by Evan B
This is probably a dumb question but... You mentioned not needing ET lugs, does that mean I could reuse the stock lugs?
Evan, that's not a dumb question at all. You are correct, our wheels do not require ET lugs. As a matter of fact, ET lugs won't even seat properly with our wheels. Most other wheel companies produce their wheels as a "one-size fits all" type of deal. This means that their hub opening is larger than needed to be able to fit various makes and models and likewise their lug opening is larger than needed to fit the various stud sizes on different makes and models.
The hub opening on our wheels is designed to fit like a glove on Toyota hubs and the lug opening has very little play. You will have to use bulge seat lugs with our wheels so to answer your original question, the stock shank/mag lugs will not work with our wheels.
