Chemical Guys Products... Rave!
TheeMikeB
If you haven't heard of these products I suggest you give them a shot. I started doing self detail stuff about 3 years ago when I bought my first Porter Cable DA 7424 and some Lake County CCS pads. I tought myself with videos and such online from Autogeek.net and had decent results with meguires off the shelf products (clay/cleaner wax/polish/wax).
As I got better and more confident I ventured into better products and was turned onto Chemical Guys from a detailer that did my boat one year. He recommended a few products which I used and they did good but one of the biggest problems I've found is cleaning the pads, it was a total pain and I couldn't justify spending $120 for a professional pad washer. Especially since it's a frigging 5 gal home depot bucket with a spinner thing in it.
Then i neglected my cars for about a year since I was traveling for work a ton, and had a pregnant wife at home. Free time for car maint was non existent. Until finally I had enough since my black G35 looked like a$$. I went back to Chemical Guys site to order new pads and check out their new products and I stumbled across their new "V" line of products. All I can say is wow it can't really be this easy!
I watched some of their videos on the website and thought It was worth a shot. This one in particular How To Remove Swirls, Scratches & Polish Paint with the Porter Cable 7424XP - Chemical Guys - YouTubeIt was following the basic 5 steps so nothing out of the ordinary except that each level of paint correcting compound finishes to a polish ready state. Other products you need to go up each level of correction polish to prepare for final polish. Much like using each grade of sandpaper from rough to somooth to complete the finish.
SO, I bought the V36, V38, and Black wax along with Orange/White/Grey 5.5 inch pads for my PC DA 7424. I followed the directions exactly as it said and my cars came out AMAZING, super easy no streaks, residue, or dust like I"ve had with other products. 5 pea size drops on the pad, spread over 2x2 area, work at high speed and wipe right off. And I mean wipe right off! ZERO residue as I've had with other greasy products.
BUT THE BEST PART which I didn't even realize until I went to wash my pads is that the polish is WATER BASED! My pads washed out in MINUTES by just running and agitating under warm water. I did two cars with my pads and they still look like new, simple wash out was easy. No nasty caked up pads. Finally a super easy to use product that ANYONE can do and easy clean up.
Now having said that, the V36 got out all the Minor swirls and scratches but I sill have some deeper scratches that will require more work so I purchased the V34 along with a yellow pad for the heavier scratches. I have yet to try the v36 but I'll follow up on here when I do. I plan on trying it on my bush scratches on my black 4runner too. Why not keep her clean and shiny as long as possible :)
Oh and a week later....
Also after my initial order and success I decided to try some of their other products and purchased the "clay block" and lube kit which is a resuable cleanable claybar system that uses like a rubber foam. I have yet to use it since I orderd it after I used my old school clay but it looks promising, I also orderd the "Gel black forever" and put it on all my exterior plastics and they look brand new.
Just thought I'd share a good experience with a great product and hopefully save someone else time and restore their rig.
Rave over.
Car Wash, Wax, Polishes, Microfiber Towels and Best Auto Detail Supplies - Chemical Guys Professional Car Care Products - Wholesale and Retail
Just thought I'd add, their Maxi Suds II soap works great in a foam gun, and is a way better value than the Detailer's Pro soap made for foam guns.
I'm with you, and I'll be using Chemical Guys for everything now.
Good to know, I got the Mr. Pink wash for free as a bonus with my last order. For the bucket wash but it too worked well.
With your 4runner and G35 being black, for you next Chem Guys order get some Blacklight, V7, and some Mr Pete's or 50/50 wax. If you want a stellar wax, spring for the Ezyme. Absolutely stunning.
One coat of Blacklight applied with the Porter Cable. Wipe off.
Wait 15 to 30 minutes, then apply another coat by hand. Wipe off.
Wait 30 minutes to 1hr, apply wax. Let sit 20 to 30 minutes, wipe off.
Spray on V7. Wipe off.
Second the motion on v7 and Pete's 53. Both are awesome on black. I don't have black light yet as I'm putting through some prima amigo. Good stuff as well
Love all there stuff...I have black cars! I use their liquid pad cleaner and let them soak a bit. Flush with water an spin dry on the porter cable. Works like a charm.
I have a couple of products in my arsenal from CG that I liked and continued to use. Their WSR; water spot remover and Citrus Wash & Clear are two of them.
I tried chemical guys products because my regular products distributor was out of pads. Chemical guys have me some stuff to try out with their hex pads, but I can say with confidence that I would not buy Nything again. Once you try out Wizards products its hard to use anything else.
delislerebecca
