Old 04-09-2015, 03:54 PM #1
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Vision X 8.7” 90w LED Light Cannon – First Single Source LED Light to Achieve 1000m!!
Vision X 8.7” Round 90 Watt LED Light Cannon – First Single Source LED Light to Achieve 1000m/3280ft of Usable Light
Total Automotive Performance is proud to showcase the new 220 millimeter (8.7″) artillery from Vision X Lighting. This marks another groundbreaking move by the progressive light manufacture, as they have continued their exclusive alliance with Luminus, the world’s leading big chip LED manufacture. This is the first Single Source LED light to achieve 1000 meters or 3280 feet of usable light. Like the other Cannon LED Series lights (4.5″ & 6.7″), the new 8.7” Light Cannon supports snap on filters to change beam and color, turning this light into 20 lights in 1. The rugged single-bolt mounting platform ensures a strong hold under high vibration, while the Hybrid Aluminum/Polycarbonate housing is engineered for extreme environments.
Exclusive Technology:
This exclusive 90-Watt LED chip is the world’s first round single chip high powered LED, which produces an unmatched seamless beam pattern. The 90-watt Luminus Ultra-Premium LED combined with Vision X Lighting’s Prime Drive, Integrated Thermal Management and proprietary Iris Reflector Technology produce amazing lighting distance and reliability, with a smooth light pattern.
Lightweight and Tough:
This leading technology is encased by a lightweight, high-strength Hybrid Aluminum/Polycarbonate housing (just 10.36 lbs.), providing the optimum combination for enduring the hottest, coldest, wettest (IP-68 waterproof rating) and most rugged conditions.
Protection and Improved Visibility:
Up to 20 different Light Cannon Cover Filters are available. Each polycarbonate translucent cover also protects the Light Cannon as well as improving vision in dust, fog or snow. Each is finished with a glow in the dark printed “X” for a unique look at night when the Light Cannons are off. Cannon Covers are available in clear, blue, red and yellow colors along with euro, trail flood, wide flood and elliptical beam changing covers.
Unbelievable Value:
The Light Cannon LED light comes standard with Vision X Lighting’s Extended Warranty and is exceptionally priced at $649 for a single 8.7″ light, or available in the Light Cannon Kit with two 8.7″ Light Cannons and Wiring Harness for $1,299.
Key Features:
  • 3280′ of Usable Light (1000M)
  • 90 watt Luminus Single LED for Smoothest Pattern
  • 8.7″ Round with 10° Narrow Beam
  • 20 Optional Snap on Driving Filters – Available in Spot, Euro, Trail Flood, Wide Flood, Elliptical Beams and Available in Clear, Blue, Yellow, Red Colors
  • Optional Black Out filter with Glow In The Dark “X”
  • Universal Single Bolt Mounting
  • Innovative Hybrid Construction, just 10.36 lbs
  • Advanced Heat Sink
  • Proprietary IRIS Reflector Technology
  • Prime Drive for Enhanced Reliability and Output
  • Integrated Electronic Thermal Management
  • Polycarbonate Lens
  • IP-68 Waterproof
  • Weatherproof Deutsch Connector
  • Patent Pending
Technical Data 8.7″ Light Cannon LED
  • Warranty: Extended
  • Raw Lumens: 5,800 lm
  • Wattage: 90
  • Weight: 10.3 lbs / 4.7 kg
  • Dimensions: 8.71” x 7.92” x 10.57”
  • Input Voltage: 9-32V DC
  • Amp Draw(12V): 7.5A
  • IP Rating: IP-68
  • Vibration Rating: 15.6Grms
  • Operating Temp: -40 ~ +85
8.7” Light Cannon LED Light (90 watt, 10° Beam)
Part# 9890852 (CTL-CPZ810) – 1 Light & Pigtail $649.00
Part# 9890074 (CTL-CPZ810KIT) – 2 Lights & Wiring Harness $1,299.00
Use T4R for special pricing
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
HTML code is Off
Vision X Tantrum Rock Light / Accent Light Kits - $119 shipped. TotalAutomotiveLV Total Automotive Performance 7 03-29-2017 05:07 PM
VisionX 4.5" LED Light Cannon - 59' x 1000' Usable Light Distance TotalAutomotiveLV Total Automotive Performance 3 02-15-2017 04:39 PM
Vision X Light Cannon 4.5's W/Covers Phillburt57 For Sale: T4R Items 0 11-21-2014 07:36 PM
