Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 07-12-2009, 09:44 PM #1
CBR_GUY_IA CBR_GUY_IA is offline
Member
CBR_GUY_IA is on a distinguished road
Member
PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure
PRODUCT GENERAL INFORMATION
PG011-05
REVISED
October 13, 2005
Title:
FUEL INJECTOR CLEANING
Models:
'90 - '06 Toyota & Scion Models With Port Electronic Fuel Injection
TSB REVISION NOTICE: ^ June 9, 2006: In the Required Tools & Material section, part numbers have been updated (TYG S-Line Device and Toyota Adaptor Pak), and the note with ordering information has been updated. Previous versions of this TSB should be discarded.
Introduction
Due to fuel quality concerns, some Toyota and Scion vehicles with Port Electronic Fuel Injection may experience clogged or blocked fuel injectors. The following procedure has been developed to clean the fuel injectors.
Applicable Vehicles:^ All 1990 - 2006 Toyota and Scion models equipped with Port Electronic Fuel Vehicles Injection (EFI).
Warranty Information
Repair Procedure
1. If the fuel injector nozzles are visibly blocked or if the injectors do NOT pass the fuel injector volume test, complete the fuel injector power flush using the following instructions:
A. Before an injector cleaning is performed, it is recommended that the following items be cleaned with Toyota Throttle Plate Cleaner (P/N 00289-1TP00):
^ Idle air control device
^ Throttle plate (both sides if possible)
^ Throttle body
B. Bring the engine to operating temperature.
C. Disconnect the fuel pump electrical connector.
D. Start the engine. After the engine has stalled, turn the ignition switch OFF.
E. Disable the fuel return line by blocking the line or installing the appropriate plug in the return outlet, if applicable.
NOTE: Do NOT clamp plastic lines.
F. Install the device adapter to the fuel line and then secure the swivel fitting on the end of the hose.
G. Make sure the ball valve on the device is turned OFF (valve handle is crosswise to device). Screw the can of EFI cleaner (P/N 00289-1PF14) onto the device can adapter.
H. Open the valve on the device, start the vehicle, and allow it to run until the engine stalls.
I. Turn the ball valve OFF and remove the empty can.
J. Place a shop towel over the can adapter and slowly open the ball valve to depressurize the system.
K. Remove supply and return line adapters, reconnect vehicle fuel supply and return lines (replacing any fuel line gaskets and seals), and connect the fuel pump electrical connector.
L. Before starting the vehicle, pressurize the fuel system and check for leaks.
Run the engine for 4 - 5 minutes, and then snap the throttle several times to dislodge any carbon that may remain in the system.
2. Add 1 can of Toyota Non-Pressurized Fuel Injector Cleaner Fuel Tank Additive (P/N 08813-0080DS) to the fuel tank.
3. Road test the vehicle to verify normal operation.
CBR_GUY_IA is offline   Reply With QuoteReply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel Injector Cleaning Thai Maintenance/Detailing 25 01-25-2023 06:06 PM
Article: Why cars won't start Thai Maintenance/Detailing 0 04-06-2006 07:45 AM
fuel system additives RICK Maintenance/Detailing 3 02-20-2005 02:30 PM
2003 Acura MDX Thai Comparisons & Reviews 33 06-01-2004 09:07 PM
Performance Exhaust Systems Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-25-2003 06:00 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
