Front ABS Ring Spinning Freely
Nelsonmd
I am installing my new front axle bearings, and I am running to some trouble with the ABS ring and retainer. I pressed everything in and the ABS ring and retainer are freely spinning.
Progress1-1.jpg~original
Anyone know why this would be happening? I have continued pressing on it, but it doesn't budge, and is still loose when I release pressure.
I checked my other hub that is still fully assembled, and the ABS ring spins, but the retainer doesn't. That doesn't seem right either. Any ideas?
Aw come on, I know people have replaced their front bearings before. Someone's got to have some insight here...
No idea Nelson, this and the upper BJ press-into-knuckle are two fixes I leave to others.
Maybe PM Dous, and see if he can get in touch with Singtoe, who has done such before.
Bump!
I have also noticed this, mentioned it on a wheel bearing thread and had a search.
I have noticed EXACTLY this on my spare hub carriers that I'm building up for an easy fit.
Anyone else noticed it?
It might explain why our ABS is *so* terrible sometimes if you hit a bump.
I assume when the hub nut is torqued up it locks it in place?
