Ottopit's 2002 SR5 build thread
ottopit
Hi,
I plan to use this post as a placeholder for any mods I do and document any work I do with pics and writeups. I know this board has helped me with my limited mechanical experience and knowledge time and time again.
So hope you enjoy it and will post pics soon
BLACK 2002 Sport Edition 4runner- purchased new here in Denver
My Sidekick
UPGRADES & MODIFICATIONS - As of May 27 2015.
Suspension:
Toytec 2.5" spacer
Toytec 1" Diff drop
Bilstein 4600 shocks & struts
Wheels:
stock- plasti-dipped Anthracite
Tires:
265x75x16 Wrangler Armortrac
Engine & Performance Upgrades:
Deckplate mod
B&M Supercooler 70268 (bypassed Radiator)
Airaid Jr Intake w/Dry Synthamax filter
Brakes
-stock
Drivetrain
-stock
Electrical Modifications:
Interior Upgrades:
ScanGuage II
Stereo:
Clarion VX404
Polk DB woofers and tweets
JBL Sub woofer
Rockford Fosgate 10F Cap
Audiocontrol EQS
Audiocontrol 6XS
Exterior Upgrades:
- DEEZEE tube steps - removed
- Plastidip emblems
- Yakima ski rack
- black toyota bug deflector
- black toyota sunroof wind guard
Services and Maintenance performed by me:
Transmission Drain and Flush with Redline D4 ATF
Rear/Front Diff/Transfer Case - Redline 75W90
Oil change - Redline 5W30 w/K&N Oil filter
MAF sensor cleaned - CRC MAF cleaner
Throttle Body Cleaned - CRC TB cleaner
NGK spark plug and NGK blue ignition wires
O2 sensor replacement - around 90,000
Fuel filter replaced - around 90,000
Services by shop or mechanic:
MotorVac service May 9 2015 at 138750mi
Timing Belt/Water Pump/Accesory Belt/ Thermostat replaced at around 120,000mi
Future Upgrades: A very loose order based on available funds
- Airaid JR Air Intake w/dry Synthamax - Installed
- Paint Interior Plastic/Dash etc Black
- Corbeau BAJA XRS seat swap - Purchase planned next month
- Second Skin sound Deadening
- Replace Factory Carpet w/Black,
- Replace Headliner (Black)
- BudBuilt Front skid and belly pan
- TRD Exhaust
- Big 3 and Battery swap
- CB equipment
- Addicted OffRoad Plate Front Bumper
- Stubbs HD SKO sliders
- Addicted Offroad or CBI rear bumper
- IPT VB upgrade
- Doug Thorley performance headers
- Tundra Brakes 13WL 231mm w/extended lines
- TRD 2nd gen Supercharger purchase next year
- URD 7th injector purchase planned along with supercharger
AIRAID Jr. intake installed
Pretty easy install so I really didn't go into detail, basically if you can turn a screwdriver and reattach hoses you can handle this...basically anyone
I cleaned the throttle plate and MAF sensor while I was at it
Basically the big result is cleaning up your engine bay, other than that it's got a louder sound when you hit the gas haven't noticed much gain in hp or anything, but I didn't really expect to,
Here it is with the stock silencer:
Cleaned out TB and MAF
Here are the after photos:
shot of the Airaid and deckplate
NEXT up will be Corbeau seat install
Also probably will start painting the dash and interior plastic pieces between now and when i get the seats in
A**holes talking S***:loco: easiest way I can say it.
OK.
Nice 4Runner, OP.
I shouldn't have asked what the deal was with the other guy deleting his threads all over the place, but since he kept deleting all of his threads I couldn't ask in those.
It just seemed really,,,, weird..
Carry on.
:peace:
Clean 4Runner! Your paint looks a lot better than mine. I am down in the Springs, we should hit up a trail sometime this summer.
Thanks! the picture makes the paint look better than it really is, it's got some scars. Cool, definitely should hit a trail
Dang, what do you use to clean your engine bay? Haha mines a wreck and every time I spray it off I end up getting water in where the spark plugs go.
I use simple green and spray on some shop rags and wipe it down. If it's really dirty i'll put some rags over places like the alternator, battery anyting electrical, spray on some simple clean or engine degreaser and then spray it lightly with a water hose.
It's dirtier than the pics are showing i just hit the 'high spots'
