Closed Thread
Old 06-08-2011, 02:22 AM #16
mom's Avatar
mom mom is offline
Banned
mom is on a distinguished road
mom mom is offline
Banned
mom's Avatar
Originally Posted by KSWAY View Post
Threaded rod type works just fine..AS LONG AS YOU USE IT RIGHT..
I decided that I'll replace my Tokico shocks by borrowing TWO spring compressor kits (one from AutoZone, the other from O'Reilly).
I'll put at least three of those threaded rods with hooks on the truck spring, the additional rod, for safety.
It is interesting to note that over in this thread, we found that the Toyota factory shop manual specifies a special service tool which uses a bench vise to compress the spring:
Which, a user posted a picture of in use:
mom is offline
Old 06-08-2011, 10:35 PM #17
Charlee78 Charlee78 is offline
Charlee78 is an unknown quantity at this point
I did used that tool in the past but that was before we began to dismantle struts like ours. Since then we use the one bolted to the wall. The first time we used the tool that Toyota suggest on a runner strut, we broke 2 different tools on the same strut and we had to bring it to another shop to do the swap for us.
1996 Runner SR5 5Spd with e-locker, Deckplate Mod with TRD Air Filter, Vortex muffler with dual pipes on the same side, Clear corners and bumper lights, 2 peices front grill insert, Blue led interior with Reverse glow gauges, Vent visors and Hood Protector, Toytec 3" lift
Fire extinguisher, 285 75R16 BFG All Terrain.
Old 06-08-2011, 10:40 PM #18
twitchee2's Avatar
twitchee2 twitchee2 is offline
twitchee2 is on a distinguished road
twitchee2's Avatar
I bought some cheap harbor freight ones....they just bowed, the spring didnt even compress. I took them to midias paid the guy $20 to assemble them and i was one my way.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
Old 06-08-2011, 10:45 PM #19
thirstyturtle's Avatar
thirstyturtle thirstyturtle is offline
thirstyturtle is on a distinguished road
When I did this I bought a hydraulic one from Northern Tools on my credit card, used it, returned it the same day and got every penny back. I've actually done the same thing for a number of expensive one-time-use tools.
::I'm a horrible person::
2000 SR5 4x4 DDM
17" MB TKO's, 2.5" rear spacer, 265/70/17 Nitto Terra Grapplers, 1" Front Diff Drop
SOLD 2006 T4R Sport V8 4x4
Daystar 2.5/1.5, 265/70/17 Firestone Destination A/T's, All-Pro Offroad 1.5" Wheel Spacers
Old 09-05-2011, 12:52 AM #20
mom's Avatar
mom mom is offline
Banned
mom mom is offline
Banned
mom's Avatar
Your price, at Midas, far surpasses what I found out here in the Silicon Valley of California.
I had asked Goodyear how much they'd charge for putting these shocks in and they quoted $100 per wheel, or $200 in total.
To close the loop, I finally bought the Bilstein shocks and rented (for a $50 deposit, good for 90 days) the free spring compressor tool from Autozone.
Which style of spring compressor do you recommend using for a 3rd-generation 4Runner?-spring_compression-jpg
mom is offline
Old 09-05-2011, 01:01 AM #21
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Find an independent shop, they will usually charge much less.
This is one job I would never tackle myself. Too much liability.
Old 09-09-2011, 02:21 PM #22
mom's Avatar
mom mom is offline
Banned
mom mom is offline
Banned
mom's Avatar
Thank you all for your wonderful advice on compressing strut springs!
Thanks for the warning.
I was, at first, apprehensive; but, it turned out, since I am a newbie, most the effort in changing my struts was in figuring out the critical step of immobilizing the suspension BEFORE re-installing the shocks.
In hindsight, the actual spring-compression activity turned out to be one of the simplest and easiest and drama-free steps in the strut replacement procedure!
To complete the picture, my first strut took hours (simply because I had trouble understanding the FSM-unexplained step of "stabilizing" the suspension). The actual spring compression step was not what took any time.
After thinking about the problem for a while, my second strut was done in 30 minutes; and the third strut (pictured above) only took about 20 minutes from chocking the wheels to the final test drive!
The spring compressed without drama; the bolt slid in like it was greased!
Knowing what I know now, I could easily & safely do the whole job again, both wheels, in less than 40 minutes, from start to cleanup (assuming additional suspension, brake, and steering diagnostics are not performed as part of the procedure).
To be specific, for others to benefit, I used the strong (and free!) Autozone spring compressor (90-day free loaner!) to compress the coil spring; and, I used a Sears bottle jack to immobilize the suspension BEFORE removing the struts in the first place!
  • OEM brand, MacPherson Strut Spring Compressor #27036
    • OEM Customer Service: 866-458-2472 (Mineola, NY)
  • Sears Craftsman hydraulic 4-ton bottle jack (P/N 950281, 8 inches to 15-3/8 inches)
Gory details, as always, for those interested, are in these three related threads:
  1. How I replaced my front struts in my 3rd-generation Toyota 4Runner
  2. How I went about choosing the replacement struts for my 4Runner
  3. How I went about choosing the spring compressor for the job
Personal note: I hope these links help other newbies! But please realize ... for some strange reason, while most are appreciative, a vocal minority here apparently get emotional and unhelpfully clutter those threads with decidedly non-technical content ... (you'll understand when you read the threads).
Which style of spring compressor do you recommend using for a 3rd-generation 4Runner?-fsm_stabilizing_the_lower_control_arm-jpg
mom is offline
Closed Thread
2wd front shocks , shocks , spring compressor , tokico
Recommend a Portable Air Compressor Jeffrey_VB Engines / Suspension / Wheels / Tires / Audio / Accessories 17 10-30-2017 06:00 AM
no need for a spring compressor Elton H 3rd gen T4Rs 33 08-20-2012 06:47 AM
2010 4Runner is here. Which generation's body style do you like? txt4r 5th gen T4Rs 17 09-26-2009 04:22 PM
Spring Compressor (used once) jerseygeorge Classifieds - buy & sell (no commercial ads please) 0 08-23-2008 12:03 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
