06-03-2011, 10:31 PM
Stretch your CV boots
When I had my CVs re-booted I had the shop stretch the boots some. After installing them I realized that they were stretched a little to far.
If the ribs on CV boots touch, here is what I did.
I popped the clamps off (shaft side) and slid the boots down the shaft till the flutes don't touch at normal ride height and going straight. Then I hose clamped them in place. Don't over stretch them! They still have to have room to stretch more when turning and drooped.
How to:
This is how the boots looked straight out of the box. Notice that the biggest flutes are touching.
I then took two of the small hose clamps and joined them together. I did this to keep things small. (this should keep them balanced also.
Then I popped the clamps off by tapping a small screwdriver into the keeper.
This is what they look like afterward.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
06-04-2011, 12:31 AM
Nice. Just keep an eye on it because it may pull back to stock location after a while, should save ya boots though!
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
09-15-2011, 11:13 AM
Update: They are holding up great and also haven't moved.
09-16-2011, 01:18 AM
That's good to hear they're holding up! I did this:
Boot Slide With No Glue - TTORA Forum
I did, however, promptly break both cv's not too long after I did the mod so I'm not sure how long they should hold up. After sliding a new boot on and band-clamping the piece of the old boot into the groove, those cv's were definitely not going to slide back though. None of the ribs were touching at full droop too.
97 SR5 5 speed, 285/75/16 Duratracs, adjustable 3" Toytec coilovers, 8 wrap LC coils and 5125 Bilstein shocks, Addicted Offroad bumper, M8000 winch, Addicted Offroad rock sliders
10-19-2011, 09:28 PM
Hello Gerdo!
Sorry to bother you but, any update from your boot slide mod?? Haven't moved?
How much do you slide the boot? An inch? Or less?
Many thanks!!
1994 Toyota 4runner
02-14-2012, 11:49 AM
One of my front CV's is leaking a bit, I'm going to try this out, thanks!
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
02-14-2012, 11:52 AM
Originally Posted by MDST
Hello Gerdo!
Many thanks!!
Still holding tight.
I slid them inboard till the bellows don't touch when the wheels are straight.
01-31-2013, 09:58 AM
Very interesting, i may have to try this
E-Locker, Bilstein 5100,LX 450 Coils, Tundra Wheels Graphite, 33'' Duratracs, 1.5" wheel Spacers, Energy Suspension Sway Bar Links and bushings,Roll Bar, LED's, Sport Hood! XRC 9.5k Comp Winch Custom Mounted, 3rd Row Rumble Seat, B&M Tranny Cooler, Tundra Brakes, 4XInnovations Sliders, Uniden 520XL Pro CB, 4' Firestik.
My Build Thread!!
http://www.toyota-4runner.org/3rd-ge...8-limited.html
01-31-2013, 10:10 AM
Mine have been this way for close to a 10 months to a year. Only difference was I used two worm clamps per side, 180* from each other to "balance" the weight. I haven't had a single problem.
2000 Sr5 4wd. eibach/LC coils/ bilstein 255/85 maxxis bighorns, Addicted offroad bumper.
01 325Ci
08 Is350
01-31-2013, 08:03 PM
I did this mod in my rig month a go ( Land Cruiser Prado 96 to 02 same platform as 4Runner 96 to 02 ) with one hose clamp per side and holding up tight!!
Cheers
1994 Toyota 4runner
01-31-2013, 10:13 PM
It's been 19 months on mine. Still holding tight and no leaks. Also the boots look brand new.
01-31-2013, 10:15 PM
Gonna do this on my next axle install.
My Build Thread!!
01-31-2013, 10:28 PM
I'm going to address mine this weekend...
09-15-2015, 07:33 PM
I've been searching... so basically to remedy the grease problem we can do this mod or buy 2 new TC / Tundra axles for $950?
09-15-2015, 07:51 PM
I'm not sure what grease problem you are referring to.
Here's what happens when you install a suspension lift on the front of these vehicles... The angle of the CV shafts from the front differential increases. Because the "ribs" that allow the CV boot to flex over the CV joint change their normal angle, some of the inner ribs will touch. This is mostly of concern on the inner side of the CV shaft. Driving for many miles with the ribs of the CV boots touching will cause them to wear on each other and form holes. Gerdo showed us a method for pulling the shaft-side of the boot outward a little. This will put tension on the boot and pull the ribs apart far enough that they no longer touch. This can be one way to extend the life of the CV boots after lifting the front suspension. Of course, if a CV boot rips open, then you will have a grease problem
*Edit: While we are on this topic... Gerdo, or anyone else who has used this method, how long did this mod hold up for? Did you get a normal lifespan out of the CV boots after this mod, or even just reasonable?
I did this to my CV boots after my lift, but it's barely been 1,000 miles. I need to get under there and do an inspection. My CV boots are already brittle and look like they might crack, just from age.
I have a 9" body lift.
Shooter's Build
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Inner cv boots
RunningRick |
3rd gen T4Rs |
6 |
10-20-2010 06:28 PM |
CV Boots Again!?
technoholic |
4th Gen T4Rs |
1 |
05-02-2010 11:21 AM |
cv boots
cooljello6233 |
3rd gen T4Rs |
6 |
08-01-2009 11:40 AM |
Cv Boots
edub152 |
3rd gen T4Rs |
3 |
05-19-2008 03:01 PM |
