02-05-2012, 08:19 PM
Gerdo's rig build thread
My 4runner, I bought it brand new on August of 99. The dealer didn't have what I wanted so I ordered (re-directed) the rig I wanted. It is a 2000 Sport, 3.4L, 5 speed manual, 4x4, loaded.
The first few years I did nothing to it as far as mods, just maintenance and drive it, about 30,000 each year for the first two+ years.
I used to have a Jeep CJ5 back in high school and wheeled all the time. My world got busy and I stopped wheeling.
About 8 years ago I got the bug to start modding my rig.
Suspension is where I started and went thru some versions.
Are we ever happy with our lift? doubtful
Do we want more lift? always
My first "lift" was a set of airlift bags in back. They were great but I realized that I wanted to lift the whole vehicle and not just get rid of the tail sag. I returned them after 2 weeks. Stock coils (~150#). I also replaced my shocks with "M" brand shocks, worst decision. Two weeks later I replaced those with a set of HD Bilsteins. Great shocks!
2nd lift. Tundra TRD coils (~595#) in front, OME 890 (190#) in back. Great ride and nice amount of lift.
3rd. Replaced the 890 (190#) with 891 (210#) for a little more lift with added weight.
4th. Added a ToyTec topout spacer in front and 10mm trim packers in back.
5th. swapped out the TRD coils for ToyTec coilover setup. (600#) and replaced my rear shocks new-bilstein-shocks-5100-test-and-review-t406.html with Bilstein 5100
6th. I just bought a pair of 9.25 wrap LC coils (160#) for the rear. I'm hoping that they compress to give me ~4.5" then I can bring up my COs if needed. They gave me ~ 4.5" of lift with my normal load. The LCs ride/flex great but compress too much with all of my wheeling/camping/ ExPo gear in it.
7th. OME 861 (220#). 11/15/11 The 861s are in and feel great. The fresh coils yielded an additional 1.25" of lift with my daily load. I'm sure they will handle my add-on gear/load better too.
I'm running Bilstein HDs in front with a ToyTec coilover setup mounted on them, 600# coils. I'm getting just under 4" of lift with them.
The back, I have gone thru 890, 891, LC 9.25 wrap and now OME 861 coils. I'm getting ~5" with them and my usual load. I running a Bilstein 5100 and are for the F-150 with a 6" lift, BE5-6528-H5. They are a stem mount on the top so there is no need for the eye adapter. Extended length is 21.5" and collapsed is 13.27". The valving is 389/94. They are stiffer than what is spec'd for 4runners (their valving usually is ~255/70).
With my usual load, the ride is firm but not harsh. I'm happy with the ride, flex and height.
I wish I started here first.
**As I have gone along I have replaced shocks to increase travel but only use Bilsteins!**
***If I was to start over I would start with Coilovers in front. Even if I only wanted a couple of inches. This way I could dial in the exact height/rake I wanted for the rear coils of choice. ***
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
02-05-2012, 08:20 PM
Armor
I needed to protect the soft belly of my rig so I made a full set of skids.
And a gas tank skid.
My good friend encouraged me to produce and sell the gas tank skidplates.
And a prototype pair of my friend's lower control arm mount skids.
Read diff armor
02-05-2012, 08:22 PM
Miscellaneous Mods
CB
Tabs welded onto my front swaybar links. They keep the end from spinning so I can disco easily for wheeling.
ARB compressor (for OBA and rear locker) squeezed in. I had to build a mount to allow it mount upright.
I have the wide flares and 265/75-16 tires. I'm running Spidertrax 1.25" hub centric spacers.
Looking out the drivers window at the front tire w/spacer
Rear w/o spacer
Rear w/spacer
Front w/o spacer
Front w/spacer
The front and rear track are different. The front is 59.3" and the rear is 58.9, a difference of .4"
I needed a second battery for camp power. I have a 12 volt heated blanket, Engel fridge and power inverter for charging batteries and running my Laptop computer. Where to put it. I could have turned the stock battery and doubled up next to it but that is the only possible space under the hood. I have a winch power cutoff mounted there so this was an issue. Another option was where the spare tire was.
Misc Threads
Top out spacers
FYI- Tire size, Lift and Fit
http://www.toyota-4runner.org/mainte...-gear-oil.html
Stretch your CV boots
http://www.toyota-4runner.org/audio-...mportance.html
02-05-2012, 08:37 PM
Bumpers
First I built a Pro-runner style light bar that was bolted to the "bumper". It really proved how cosmetic the bumper is.
Then I built my rear bumper. It took some time and the swingout is going to be re-built soon.
The front bumper holds a 8000# winch with synthetic rope.
My sliders are 2x2 square tube. These may be changing too.
Update, 11/27/12
I built my new tire carrier before my Kokopelli trip last spring.
It holds two 5 gallon NATO Jerry Cans. The carriers are built so I can have one, two or even none bolted on. It also holds my Hi-Lift and my spare.
The last two days, I made some changes to my Jerry Can holder. I turned one carrier sideways and also built a hinged keeper/lock strap.
02-05-2012, 08:42 PM
Real Name: Jim
Real Name: Jim
Now this is a thread I have been waiting a LONG time for!
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
02-05-2012, 08:57 PM
Real Name: Zane
Real Name: Zane
X2
OLD - "Miss Molly Brown" = '96 Limited 4WD - Anthracite Metallic - 265/75/16 Cooper Discoverer ATR - 4 Spidertrax 1.5" Wheel Spacers - 1 pair of Hella 700FFs
NEW - '06 SR5 V8 4WD - Shadow Mica - Gibson Exhaust - 265/70/17 BFG A/T KOs - Front= Bilstein 5100s set at top notch - 2011 FJ Trail-teams coils - Toytec diff drop - SPC UCAs - Toytec swaybar relocates - Rear= Toytec Superflex coils - 2011 FJ Trail-teams Bilsteins
02-05-2012, 09:17 PM
Sorry, I just decided it was time.
02-05-2012, 09:24 PM
Great thread man....always interested to see close-ups of some of your work!
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
02-06-2012, 12:01 AM
subscribed!
'01 SR5 Sport. 2nd gen TRD S/C, URD plugs (URD 7th and 2.2 on the way), B&M Tranny cooler, full length 5"height BajaRack, toytec ultimate front coilovers, ome 891/bilstein 5150 rear, toytec dif drop, SS panhard, shrockworks front with piaa 510 and IPF 900 (converted HID), 265/75r16 duratracs, 55w 4300k HID's, smoked LED tails, 20% film on all windows (except windshield), bluetooth/android obd2 reader/gauges.--- SOLD
2010 Shoreline Blue TE. KDSS, ARB, Warn 9.5xp, OME, Duratracs. TONS more to come on this one
02-06-2012, 12:41 AM
Real Name: Isaac
Real Name: Isaac
well glad to see im not the last one to jump on the band wagon... this will be cool to see, you have some ingenuity my friend and im proud to sport your stuff, i am interested to see what else you do!
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
02-06-2012, 09:18 AM
Nice work.
How do you have your fridge secured up front? That is one of the things I have been trying to figure out in mine.
02-06-2012, 11:39 AM
Originally Posted by Bighead2001
Nice work.
I don't have it in right now but I will be remounting it the beginning of April, I'll get pics then. Basically, the feet drop into the shelf that I built and I secure it down thru the handles to the tiedown and the seat mount. I did mount the handles upside down so the pressure wouldn't deform them. I'm using some rafting type straps. I also need to add a 12v outlet near the fridge.
By the way, The Engle fridge is worth every penny. Wheeling for a week and not dealing with ice, sloshing water and wet food. Knowing that food isn't going to spoil in 110*+ heat too.
The fridge is angled to maximize space and still have the lid open as much as possible. My wife and I can still sleep with the fridge in place.
02-06-2012, 12:34 PM
Luv your rig and am glad to see a build thread.
I really like your armor and have plans to incorporate your gas skid. Are you sure that's the only skid you're interested in producing for others???
'99 Millennium Silver Metallic T4R Limited Auto 4-Speed
3.4L 5VZ-FE V6 4x4 with Rear E-Locker
YODA Build Thread
