Originally Posted by Mattburn_owo
Did this on my 07 last night, easy swaps, somehow blew one fuse putting in one of the map lights. No big deal right? Pulled fuse, put it new one, no problem. Now car won't start, everything lights up, but when I go to start there is nothing.
Similar to when car is in gear and fail safe stops it from getting power.
Ideas?
That's interesting. I have no solution for you, but I ran into a similar issue. I swapped all of my interior lights to LED, and when I went to turn on the map lights, it blew the dome light fuse. Replaced the fuse and tried the other map light and blew the fuse again. Put the same exact LED into the door light, and it worked just fine. Put the old incandescent bulbs back in the map lights, and they worked just fine. For whatever reason, the map light sockets just didn't like the LED replacement bulbs.
