Transfer Case Actuator
Heck of a first post on my part, but I'm about to lose my mind. I just bought my 08 SR5 4x4 on Monday evening from a local non-Toyota dealer. When driving home, I flipped it into 4H and the lights were blinking but I didn't give it much thought, just figured I was doing something wrong.
Well after fiddling more on the way to work this morning, then looking up a few threads on the issue, more fiddling (driving slow, coasting, accelerating, neutral, reverse, etc.), my truck won't shift into 4 wheel.
I have a call in with the dealership, but they don't open until 9 so I'm sitting here worrying msyelf to death over it. One of the reasons I bought the dang thing was for 4wheeling fun, and I sure as heck can't put 2k into it right now.
Since it was so recent, how much recourse do I have against the dealer? I'm going to try the simpler things mentioned in this thread, and leave taking the actuator apart as a last resort. God this sucks.
2003 Limited V8
My problem seems a little different than what I have read on here. When I move my dial to 4low, nothing happens at all. No lights blinking, no clunk, nothing. Before I start worrying about the actuator, I wonder if it could be the switch or wiring.
Any Ideas?
2003 Limited V8
Any Ideas?
No ideas but similar circumstances. I just encountered the same issue with my 2008 Limited V8. Took it to the dealership and they just said that the switch signal was making it to the transfer case. Recommendation was new transfer case for $4,300 and then the light might start working... Didn't directly address the no blinking & beeping 4LO light on the dash or no illumination on the dial.
Once things warm up I might open up the dash to wiggle things around and test the wiring harness for my own edification.
I forgot to update this thread.
I had a stereo installed and when the dude did it, he forgot to plug the switch back in. That simple! Had me scared as hell that I was going to be paying big $
for a fix.
Read the rest of the thread or any of the many others on the subject. You can pull it apart but NO ONE knows how to put it back together correctly.
I know exactly how to synchronize and repair all the parts in the v8 actuator motor and have done myself. Its not that hard at all. Its simply a matter of rotating the gears by hand when they are in a known position, marking them and matching that position with the encoder. The blue gear encoder should be marked before removing the motor, if you failed to mark it, you can still move the encoder to the correct location and test with the 4lo-4hi and CDL switches to ensure that you have it in the right spot.
http://www.toyota-4runner.org/4th-g...ctuator-transfer-case-timing.html#post2419033
for a fix.
I had the same thing. Good news is it works after 7+ years, took a little cycling to get it moving again. Main difference is I bought it used from Toyota and didn't think to test and/or use the feature (like the majority of owners). Either it originally came like that (in which case their certified used program isn't as thorough as they make it sound), someone at the dealership popped it during one of the services (unlikely, but possible if they want to prevent $2,000+ warranty claims) or it wiggled loose on it's own. Regardless, the failed 4LO wasn't reported during any of the scheduled maintenance checks (use same dealer for maintenance, 30k to 100k miles). I even took it in when I first noticed it and paid a diagnostic fee. After which they claimed it didn't work but the switch did? Impossible in hindsight now that I see it wasn't connected in the first place...
Finally got around to it and the switch was disconnected. Once connected the dash lights up and I'm able to enter 4LO. After 7+ years in 4HI only it still activates. Took multiple attempts but it loosened up on it's own.
Have faith those with a stuck actuator.
photos of actuator dial indicator
This photo shows the dial in the 2WD position.
actuator dial indicator in 4 WD
Photo of dial while in 4WH (4WL doesnt affect this dial, the second motor engages 4WL). From 2WD the dial travels CW about 240 degrees to this position
Dial indicator photo of differential locked
Differential locked position
I just bought a 05 V8 Limited 4R...
Drove it from the seller's house.. put the trans into 4LO and the second I did that, noticed a large spill of "oil" once I drove into my place...
looks like its the transfer case leak - so I guess my question is.... if I don't plan on driving in 4lo (ever) do I need to get this fixed?
The transfer case is integrated into the transmission. You will need to have oil in it at all times or it could run dry and lots of bad things would happen.
Transfer case actuator timing solved
You don't need to split your transfer case to fix the actuator. It can be removed repaired and easily timed. It took me a while to figure it out but it is simple. Hard part is getting actuator back on without damaging seals. But seals are very cheap and I bought six just in case. Only used two though.
Care to post up a step by step? I was able to do it but it took me a while and I still ended up pulling the T-case just not apart.
Thank you selfless MFs!! BossAF thank you ���� �� 100 ����✌��❤️
After sitting for several months while I was deployed, our 4Runner's transfer case actuator was sticking giving me a pair of flashing lights (the green 4wd light and the yellow center differential lock light). After I trawled the forums looking for ideas here's what I came up with:
- Engaging and disengaging the 4wd repeatedly is a good first step. In my case however, no amount of engage/disengage, rocking, coasting, forward reverse was getting any results.
- Crawling under the car with a buddy in the driver's seat changing the 4wd switch is a good way to see/ hear what the actuator is doing. On my 2008, it turns out there is an inspection port that you can unscrew and view a pointer dial that gives you an idea of what's going on inside the actuator.
- While under the car, grab the front and rear driveshafts and rotate them while the buddy cycles the switch. You can feel if the actuator is binding up / and whether the differential is engaging the front shaft. If it is binding, turning both the driveshafts slightly may help it engage.
- My motor was really frozen so I had to take another step. I removed the actuator bottom plate and was able to rock the motor coupling with a small screwdriver. I marked the gear's position and moved the motor shaft about 1 revolution forward, then back about 3-4 times. The motor felt less bound up after a couple of turns. (Take care opening the case bottom as there are gears that will come off their shafts and rest on the bottom plate. Just keep the bottom plate level as you lower it from the actuator and the gears will stay put. I had to loosen the three actuator attachment bolts and remove the one transfer case guard bolt that was in the way of lowering the bottom plate of the actuator.)
- I then put it back together and had my buddy cycle the 4wd switch again. I could see from the inspection dial that it was moving about 90 degrees at first, engaging the front shaft but still beeping. After a couple of cycles (and a twist of the rear shaft) it went all the way to 4wd hi. A couple more cycles and then to 4wd low. It seems to be shifting much more smoothly now and the lights glow steady when in 4 Hi/Lo, and when I lock the differential. The inspection dial shows it traveling about 240 degrees to the locked mark.
The actuator looked brand-new inside and had lube on the gears. I didn't lubricate the motors at this point since they seem to be much happier now.
BTW, the breather hose on the actuator case was problematic for several of the owners who posted problems. Toyota used a hose that has serrated flare on the end so it will slip over the breather fitting easily. I think these serrations crack over time resulting in a loose fit / falling off the fitting leaving the actuator exposed to water (some of the pictures of failed actuators revealed rust and crud over its components, clearly water had seeped in and made a real mess). I clipped off the end 1/4 inch of the hose to remove the flared end (which looked close to failure) and re-attached it for a nice snug fit.
Inspection port / pointer dial
Inside Actuator to rotate motor coupling to free it up
Breather hose flared end removed
Thanks to all who have posted, I found it well documented how important it is to "use it or lose it" with these actuators so I'll be sure to use them weekly.
Another actuator problem
Alright sorry to resurrect an old thread but I am in need of assistance. So I recently bought a 4gen with 50K miles on it for a steal of a price. I knew when I bought it that i was going to have to replace the actuators being that it hasnt ever in its life been dropped into 4wd.
so first off, I got the 4hi actuator replaced then about a week later got the 4lo replaced. Now when going into any of the 4wd options i HAVE to lock the transfer case in order for both 4hi or 4lo to engage. When I try to turn off the locker, it stays blinking and does not fully turn off. Also, i have to engage the transfer case locker to get back into 2wd as well. This was never the case after I replaced the 4hi actuator, but is now a problem after replacing the 4lo actuator.
Has anyone else had/resolved this? I cannot find any posts with my same situation. Anything helps!
Alright, I have an update from my last post and I pray no one has to deal with the situation i was in. So as stated in my last post I had both actuators replaced. 1 month later the front diff actuator for 4-hi blew up and was replaced under warranty. I still couldnt figure out why i needed to lock the transfer case to use any form of 4wd so i caved and took it to my local toyota dealership. Long story short the transmission shop that i had install the actuator for 4lo and the locking t-case completely screwed me. They installed the actuator incorrectly and toyota said they bent something in the transfer case ultimately making it all worthless. So after i had the front actuator replaced twice and the t-case actuator once, i needed to replace the entire transfer case and actuator again. Way too much BS to go through considering my 2007 4runner only has 55k miles today.
After searching through the forums I'm still having trouble timing the actuator.
Does anyone have a picture of the lo-high and 2wd-lock-4wd dial positions for High range (rod all the way into the T case) and 2WD (rod all the way into the T case)? I see the pics of the 2WD-lock-4WD but am having trouble timing the High-low.
Do I need to do anything in particular when I change the timing, like disconnect the battery, clear codes etc or will the ECU change automaticaly by position?
2006 Toyota 4 runner 4WD V6
