Old 08-18-2015, 06:40 PM #106
Pkniland's Avatar
Pkniland Pkniland is offline
Pkniland is on a distinguished road
Pkniland's Avatar
Originally Posted by jicko View Post
Rigid lights installed, they look AWESOME!
/20150812_194337_mod-vi.jpg[/IMG]
So i guess its time for the TRD Pro Grille Group Buy?
2015 Trail Premium, KDSS, BFG KO2 275/70/17, Gobi Stealth, Hella 700FF.
Pkniland is offline   Reply With QuoteReply With Quote
Old 08-18-2015, 06:53 PM #107
SKP-4R's Avatar
SKP-4R SKP-4R is offline
Real Name: Sean
SKP-4R will become famous soon enough
SKP-4R's Avatar
Real Name: Sean
I think it's time for a visit to ICON
'15 Trail Edition Attitude Black w/ KDSS | ICON Stage 2 | Dirt King UCA's
SKP-4R is offline   Reply With QuoteReply With Quote
Old 08-18-2015, 07:01 PM #108
jicko jicko is offline
jicko is on a distinguished road
Its about time.....
Tried that, no love...... none of the Toyota dealers are interested/willing to do group buys......
I was thinking these will make good GB items:
- TRD wheels
- TRD grille
- TRD skid plate
But.... answer was no.... they think that they can move the parts at full price.... no motivations on GB....
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
jicko is offline   Reply With QuoteReply With Quote
Old 08-18-2015, 09:07 PM #109
SKP-4R's Avatar
Real Name: Sean
SKP-4R's Avatar
Real Name: Sean
I don't blame them. People will buy anything for retail if it has the holy words "TRD" written on it. the TRD Oil caps are proof of that.
Old 08-31-2015, 03:39 PM #110
Odyssey 31M-PC2150 "Trolling Thunder" Deep Cycle Battery Installation
I had looked into various battery strategies (single, dual), and considering my use case, I have decided to start with a single large capacity, deep cycle battery. As it is much simpler, easier, and lower cost to implement than a full-on dual batteries with isolator setup is.
My use case:
- weekend and short(few days) offroading trips
- driving around during the days, and camping during the nights
- maximum "offline" (car's engine not ON) time will be no longer than 36hours
- powering (offline) ARB 50QT fridge
- powering (offline) HAM mobile radio
- powering (offline) some low power LED light strips
Like many others on this forum, I have decided to use a 31M-PC2150 marine grade, deep cycle battery, from Odyssey (some claimed that Sear's Diehard Platinum 31M is the same thing).
Amazon.com: Odyssey 31M-PC2150ST-M TROLLING Thunder Marine Dual Purpose Battery: Automotive
SPECIFICATIONS
Pulse (5-second) Hot Cranking Amps (PHCA): 2150
Cold Cranking Amps (CCA): 1150
20Hr Nominal Capacity (Ah): 100
Reserve Capacity Minutes: 205
Dimensions L x W x H (in): 13.00 X 6.80 X 9.41
Weight (lbs): 77.8
Some useful info about this particular battery (voltage vs % of charge):
This battery comes with brass SAE posts, 3/8 inch positive and 5/16 inch negative thread SS stud terminals. And in order to it to hook up to the "factory" clamps without ANY modifications, ordering some Remy Battery "Stud to Post" converter is THE WAY TO GO! (Be sure to order 1 of each size) Stud to Post Conversion Adapters - Remy Battery
Also, while you are ordering from Remy, I found that their group 31 battery to be the lowest cost solution ($8.44!!!) to house the battery (a $100 battery cage is NOT needed!!): Steel Battery Tray (13") - Remy Battery
Post converters screwed in (and extra converters) and the battery tray:
Size comparison between the Odyssey 31M vs the stock Panasonic:
Once you removed the factory battery and the whimpy plastic tray, the new steel tray fits right in, and you can get a "M6 bolt/screw" (maybe 15mm long) and a washer to screw into a threaded hole as you can see in the picture below. Together with an aligned "hook", this tray is not going anywhere!
Unfortunately, with the added battery try, the factory "J-hooks" are not long enough to hold-down the battery, you would need some 10in hooks. You can get them from Amazon cheaply (with prime too): http://amzn.to/1PHfrFm
I am not a big fan of the "wing nut", hence, I dropped into home depot and picked up some 1/4" (IIRC) nut/washer/lock-washer for the "J-hooks". And 1 last final touch (not really necessary), is to use a bolt-cutter and trim off the extra length of the J-hook that is closer to the fuse box).
Here it is, all mounted!
SOLID and economical!!
Old 08-31-2015, 03:49 PM #111
LawnDart's Avatar
LawnDart LawnDart is offline
LawnDart will become famous soon enough LawnDart will become famous soon enough
LawnDart's Avatar
How long did the swap take?
LawnDart is offline   Reply With QuoteReply With Quote
Old 08-31-2015, 03:54 PM #112
If you acquire all those little things listed in my post before your start the swap, the swap itself will take you like..... 15min? Everything is plug and play, fits perfectly, no wire re-routing or metal bending needed. And extra pair of hands to help lift the 75lb battery and set that in place will help tho.
Double check the nut/washer/locking-washer size by bringing the J-hook to home depot will help too.
Old 08-31-2015, 03:59 PM #113
SKP-4R's Avatar
Real Name: Sean
SKP-4R's Avatar
Real Name: Sean
75lb?? Wow, thats like having an entire Chinese gymnast team under the hood.
Old 08-31-2015, 04:17 PM #114
LawnDart's Avatar
LawnDart's Avatar
Excellent. I was thinking of doing the same swap.
Old 08-31-2015, 04:44 PM #115
RiDE's Avatar
RiDE RiDE is offline
RiDE is on a distinguished road
RiDE's Avatar
Looks great. I'm going to go with the same setup. Thanks for the all the info. Was Amazon the cheapest you were able to find the battery?
IG: RiDETEQ
RiDE is offline   Reply With QuoteReply With Quote
Old 09-01-2015, 12:24 AM #116
Not really, but if there is any issue, Amazon will help you mitigate it, and they will pay for return shipping too. As this is an HEAVY item, I think it is worth it to go thru Amazon.
Old 09-14-2015, 01:12 PM #117
RCI Metalworks - TRD Skid Integration Plate Installed!
I want RCI's skids to protect my underbody, but I love my TRD front skid too much...... what can I do?
Thanks to Josh & RCI Metalworks, here is their solution for us!
14+ Toyota 4-Runner TRD Integration (Filler) Skid Plate
This piece of art is SUPER well made, with 1/4" aluminum (same thickness of aluminum as the TRD front skid), protecting the low hanging front differential and oil pan. (They do have a 3/16" steel version, but I chose the 1/4" aluminum for its weight benefit)
The factory front differential & oil pan skid is a joke. Yet I guess, if you have the regular factory front skid, you would damage that (and you probably would have stopped) before you hit this piece. But, if you do have the TRD Pro/TRD front skid, a rock can easily slide off the TRD skid and land on this thin, whimpy sheet metal and cause a big issue.
One of the nicest thing about the aluminum version is that it is not much heavier that that whimpy factory skid! The factory one weighted in ~7lb, while the ultra strong RCI's AL version weighted in only ~9lb!!
Some other worthy to note features:
- welded bolt protection rings for bolt protection
- access port for the oil pan (adding a Fumoto valve maybe good)
- the front plate edge sits about 1/8" lower than the TRD skid, so there is no bad edge to catch
- aluminum will not rust, no painting/rustoleum needed
- the whole installation took me like 15minutes only, everything just plug and play; I didn't even have to jack up the car
- seamless integration with other RCI skids; their transmission skid will slide underneath and behind this and bolt to the same 2 bolts, and their transfer-case skid will follows too.
IMO, if you have a TRD Pro or have a TRD Front Skid, you'd WANT this TRD Integration (Filler) Skid Plate!
** RCI GB upcoming.... LOL **
http://www.toyota-4runner.org/group-...ll-2015-a.html
Old 09-30-2015, 09:49 PM #118
Sarethx Sarethx is offline
Sarethx is on a distinguished road
Awesome stuff you have done.
Any chance we can get a shot of those DRL Leds in daylight? I also didn't see if you followed up about the regular DRLs having to remain on or not when active. I would assume not since these have their own button.
I am debating on new fogs and these were the ones I been eyeballing but haven't really seen any good shots of them on peoples vehicles.
Thanks!
2015 4Runner TE with KDSS
Sarethx is offline   Reply With QuoteReply With Quote
Old 10-01-2015, 12:04 PM #119
hamburglar210 hamburglar210 is offline
hamburglar210 is on a distinguished road
This is a great thread, thanks for all the detail. I'm sad to say that work now blocks the pictures after your June 27th update so I'll have to actually get stuff done and browse at home now haha
2013 Trail - has never been in the rain
hamburglar210 is offline   Reply With QuoteReply With Quote
Old 10-01-2015, 11:10 PM #120
Arttieboy's Avatar
Arttieboy Arttieboy is offline
Arttieboy is on a distinguished road
Arttieboy's Avatar
Actually, I found it quite distracting....... too many colors.... and especially the bright green (cannot be dimmed down) "ECO" light....
Eco light can be turned off in the settings menu
Arttieboy is offline   Reply With QuoteReply With Quote
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
wyanrard's 2003 SR5 V6 build thread/picture thread wyanrard 4th Gen T4Rs 56 02-04-2017 01:03 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
