Old 02-18-2018, 11:14 PM #1
jayhat's Avatar
jayhat jayhat is offline
jayhat will become famous soon enough
jayhat's Avatar
Jayhat’s Super White 2016 Trail Build Thread
Was going to post a couple mod threads but decided to make an official build and hopefully adventure thread. I need to be better about taking pics when I go out and also just going out an adventuring more in general. It was a busy spring/summer last year.
Originally had a 2010 SR5 which I didn’t really mod at all. Loved it but didn’t like the more refined look of the SR5s. Always had big plans to mod it, remove chrome, “trail” it, etc, but happened upon my current rig and figured that would be a better start. Bought this Super White 2016 Trail in December of 2016.
Jay4Runner5G on Instagram
Current Pic - October 2018
Mods:
Wheels, Tires, Suspension
17x8 Grey Level 8 MK6 (0mm offset)
275/70/17 BFGoodrich All-Terrain T/A KO2 E rated Tires
Dobinsons shocks (GS59-700 front & GS59-701 rear) & Coils (C59-302 front & C59-327 rear)
Lighting and Electrical
KC HiLites Cyclone hood lights
Baja Designs Amber Squadron-R Sport LED fogs
Baja Designs 20" S8 LED bar
Amber LED bumper marker light mod
KC HiLites 3” C-Series LED pods on CBI ditch brackets
KC HiLites 3” C-Series LED pods on rear of rack
Overland Equipped sPOD/fuse block bracket
Switch Pros SP9100
Misc
Overland Equipped ladder steps
Eezi-Awn K9 Roof Rack MAXTRAX Mount with Mounting Pin Set – rack front
Rago Fabrication Modular Storage Panels
¾” Birch Plywood Cargo Platform
Plano All Weather Tactical 36-Inch Gun Case bolted to rear of rack – for recovery gear
ARB Differential Breather
Shrockworks Sliders w/ dimpled tread plates
Gobi Stealth Rack
2 gallon Rotopax fuel can on Gobi ladder w/ locking Rotopax mount and Overland Equipped mounting bracket.
Cosmetic
Blackout Logo and TRDP bumper
On order / awaiting install / coming soon:
2014 Trail TFT Screen display (upper central dash)
Rear camera anytime mod
The night I got home with it. Almost wrecked on the highway on the way home. I came through the fog and some moron was going about 20 MHP, no lights, trunk open flopping up and down. Scared the shit out of me.
Almost immediately came the new wheels and tires: 17x8 Grey Level 8 MK6 (0mm offset) & 275/70/17 BFGoodrich All-Terrain T/A KO2 E rated Tires
Also added a couple Grand General 77650 Amber Thin Line 6-LED Markers
Got some Shrockworks Sliders w/ dimpled tread plates as part of a group buy. Bit the bullet and got the damn TRDP bumper valance. Also got a Set of Baja Designs Amber Squadron-R Sport LED fogs.
Got a Gobi Stealth rack as part of another group buy. Got anxious to install it, had the day off from work, everyone else was working, so I worked out a solo install method. This are the most recent exterior shots I have as of 2/18/18. Need to get out there and take some more!
jayhat is offline   Reply With QuoteReply With Quote
Old 02-18-2018, 11:15 PM #2
jayhat's Avatar
jayhat's Avatar
Next thing I took a picture of was my KC HiLites Cyclone hood light mod. Had 2 of these I’d got for free so I decided to install. I needed something to mount the switch to in the engine bay, and I still needed to installed my Overland Equipped sPOD/fuse block mount, so I used that. Lights are mounted in a double wall section of the hood with self tapping sheet metal screws. sPOD coming at some point soon.
If you take the hood liner off, you’ll almost be guaranteed to break some of the plastic poppers. Lowes sells some plastic pins marked for a Ford that work perfectly. About 2/$1.
After several iterations of various storage boxes, I decided I wanted drawers or some type. Still working on that, but the first thing I needed was a solid “cargo plate”. Bought some ¾” birch plywood, installed 7 ¼-20 rivnuts (4 back and 3 front), glued some outdoor carpet to the board, and bolted it down. Decided I wanted to leave the back 2 tie downs and also decided to leave the foam in to help deaden sound. The black plastic pieced from the side panels stick up higher than the bolt holes anyway, so I used some basic spacers over the bolt holes (just to eliminate any flex the wood may have). Front holes are about ½ inch lower than the back ones. I used a ½ steel nut as a spacer in front and ¼ inch nylon washers on the back holes. I think I used 2-2.25” stainless bolts are large washers to bolt the platform down.
Rivnuts in
Foam back in – trimmed to reveal rivnuts
Test fitting
Finished board – used a soldering iron to melt the holes in the carpet.
Old 03-09-2018, 10:24 PM #3
jayhat's Avatar
jayhat's Avatar
Added some L-Track and hooks
Old 03-12-2018, 01:04 PM #4
4Runnergenius 4Runnergenius is offline
Real Name: Chris
4Runnergenius is on a distinguished road
Real Name: Chris
Nice work, sub'd
4Runnergenius is offline   Reply With QuoteReply With Quote
Old 03-14-2018, 02:38 AM #5
Magnetic4R Magnetic4R is offline
Magnetic4R will become famous soon enough
@jayhat by chance do you have the dimension of that cargo tray you built?
'14 4Runner Limited Redwood: Suntek films, AVS visors, BAMF Sliders, WT Liners, 35% tint, TE37 18x9, 285/65 RidgeGrappler, Spidertraxx, Gobi Rack, Bilsteins 6112/5160, ICON Overland, CVT Mt. Shasta, TRD skid, RCI aluminum skids, BW flares, TC UCAs
'14 RX350 F-Sport: '02 GS430: '92 Integra GS
'14 S-Work Enduro: '13 Canfield Yelli Screamy
Magnetic4R is offline   Reply With QuoteReply With Quote
Old 03-14-2018, 02:57 AM #6
spigot1999's Avatar
spigot1999 spigot1999 is offline
spigot1999 is on a distinguished road
spigot1999's Avatar
Pretty sweet ride.
spigot1999 is offline   Reply With QuoteReply With Quote
Old 03-14-2018, 07:56 PM #7
jayhat's Avatar
jayhat's Avatar
I’m on a work trip but I’ll try to get it in the next day or two. Don’t recall off the top of my head.
Old 07-03-2018, 11:34 AM #8
jayhat's Avatar
jayhat's Avatar
Have done a lot but have not got around to taking any pics of anything. Moved my Baja 20" LED bar from the roof down to the bumper. I didn't like the idea of the light shining through the grille slats and losing some of it's power, so I cut it and got a "frame" made at a local fab shop. The diamond shape of the grille slats wont really let you make any clean line cuts, so I needed something to hide the unevenness of it. It will also be painted flat black which I have yet to do. This was a test fit.
Light is mounted in the KC Hilites 20" LED bar bumper brackets for 14-18 4Runners. Works w/ other lights too.
KC HILITES | 20" LED Light Bar Behind The Grille Bracket Set for 14-18 Toyota 4-Runner
The piece - It will also be painted flat black which I have yet to do. This was a test fit.
Was just planning on using washers and some bolts to sort of "pinch" it onto the grille slots. It's not a great way to mount as the grille holes are pretty big and there isn't much of a surface for the washers to interface with. I think the final iteration will use a flat piece of bar stock with holes in it that run the length of the top and bottom. Also only using 4 of the holes. I had no ideas where I would use bolts so I had them evenly place bolt holes along the piece.
Little handheld hacksaw made short work of the cuts. The grille is super soft and easy to cut.
truck is filthy, sorry. Freshly cut.
Test fit. Again this will be flat black.
Old 08-07-2018, 03:16 PM #9
jayhat's Avatar
jayhat's Avatar
Had Advanced Auto Fabrication of Spokane WA do my Dobinsons lift install. Great shop.
2x - Front Shocks
GS59-700
Twin Tube, fixed mount (not adjustable), suits 0-2" lift
Front springs (pair)
C59-302
100-220LBS heavy load front weight, 2" lift. 586LB
Rear springs (pair)
C59-327
200-400LB heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 271LB
2x - Rear Shocks
GS59-701
Twin Tube, suits 0-2" lift. 605mm extended, 362mm compressed $190
JUST makes it into the garage - am really anxious to empty the back out and run it down to E to see if that will let it lift up just enough to stop it from fitting.
Alignment:
Old 10-08-2018, 01:13 PM #10
jayhat's Avatar
jayhat's Avatar
Did White to Chinook Pass on the Washington Backcountry Discovery Route (part of section 2).
Old 10-08-2018, 01:36 PM #11
jayhat's Avatar
jayhat's Avatar
I know I said months ago I would post this. Still interested? I took measurements this weekend for a storage area build I am doing. I got them written down at home. I will post them later.
Old 10-10-2018, 01:16 AM #12
jayhat's Avatar
jayhat's Avatar
41.5” W x 36.5” D
Old 10-10-2018, 11:04 AM #13
41.5” W x 36.5” D
Haha, no worries, got what I needed and finished my drawers setup.
Old 10-10-2018, 11:39 AM #14
16RedRunner's Avatar
16RedRunner 16RedRunner is offline
Real Name: Mark
16RedRunner has a spectacular aura about 16RedRunner has a spectacular aura about
Real Name: Mark
Awesome!!
16RedRunner is offline   Reply With QuoteReply With Quote
Old 10-14-2018, 05:24 PM #15
jayhat's Avatar
jayhat's Avatar
Yet another iteration of my cargo storage. It's ever changing.
I decided for simplicity over drawers for the time being. Basic 12" high 3/4" birch ply shelf. Glued and pocket hole screwed together. 1" aluminum L stock and with felt added for "tracks/slides". 3/4" ply pull out shelf. Covered in outdoor carpet (interior painted white). Turnbuckled down to the runner. All other mounts installed into it with 3/4" wood screws. Side note - anyone know how much force a 3/4" wood screw into birch plywood would hold?
Water Can does not ride on top all the time. Just up there for pics. I wanted a secure mount for when I take it camping.
Pull out table is sort of a waste of weight and plywood but it's simple which is what I wanted. This is about how far I like to pull it out but it can go out a little more and still hold fine (third pic). Can just be pulled out totally if not in use.
Aluminum L stock "tracks", mounts, turn buckles, etc etc etc.
Bolted the 4 main mounts through the various aluminum pieces to sort of act as washer. Held down to the 4 stock points with quick links and turn buckles. Also moved my L-Track up to the top surface and added E-Track to the corners and behind the water can mount. I am trying out E-track for now because I can source it locally and it's a lot cheaper than L-Track.
Table surface stop
E-Track mounts
Aroslv 16 TE Super White build thread aroslv 5th gen T4Rs 13 09-24-2017 10:52 AM
RedBullGuy's 2016 Super White Trail Premium Build RedBullGuy 5th gen T4Rs 3 09-04-2016 03:46 AM
Battle Wagon's Super White SR5 build thread Battle Wagon 5th gen T4Rs 10 07-14-2016 11:15 PM
Jtolly's 2015 Super White TEP Build Thread Jtolly 5th gen T4Rs 35 11-11-2014 10:53 PM
My 2014 super white build thread ferrisd78 5th gen T4Rs 14 06-11-2014 08:08 AM
