ANTMAN'S Thread
antman
looking to add dual battery. i don't see a setup in your sig, but even so, being an electronics savant, i hope you could point me in the right direction.
looking to use stock battery as primary and run my ham radio and future inverter off the aux.
i could get any deep-cycle battery for this purpose, correct? was looking at either the odyssey 1500 or 925 (not sure if i need the 1500) or the the sears platinum marine (which is a re-badged odyssey; not sure if i should go whole-hog and get the PM 1 or the cheaper PM2). and connect with the Sunforce 150A isolator(Amazon.com: Sunforce 60113 150 Amp Battery Isolator: Smarthome)
suggestions? thoughts?
thanks in advance for the help
I'm looking at this thread, and I'm in awe.
I feel like I've dropped off the face of the earth for a month (and in reality, I just about HAVE), and come back to find Antman taking his rightful place as the king of the mod writeups!
Here's what you all need to know: the only reason my thread was any good is because Antman did all the work and/or showed me how to do anything. This is probably not a surprise. Our system was basically him tinkering with my truck, and I'd write it up. But I always felt like I was holding him back from greatness. (sniff, sniff) Now, I see this (weep)...and I'm so damn proud!
:cry2::cry2::cry2::cry2::cry2::cry2:
To what heights will he take us?
ANTMAN MOD #5
12V Outlet Mod.
This mod allows you to use your factory 12V outlet in two different ways via a switch. The outlet will either function exactly like it does now, meaning 12v power during ignition-on only, or 12v power all the time, your choice. I find it most useful for charging my phone overnight, or charging my GPS for the return trip home…
Yes. This MOD requires cutting, and drilling big ¾” holes :wtf: in Toyota plastic, yikes!! Truth be told- you only have to cut 1 tiny little green wire, and you can put the switch anywhere, so technically speaking-
You don’t need to drill a hole at all. Sticky-tape the switch to your dash, if that’s your thing. :)
Here’s what you need for the MOD:
<O:p
</O:p
· Mini Fuse tap
· 10A Mini Fuses (2)
· SPDT switch.
· 16ga wire
<O:p</O:p
... hand is lookin' a 'lil bit rough. . .
<O:p</O:p
This is what the finished MOD looks like.
<O:p</O:p
<O:p</O:p
The white wire coming out of the hole is another mod for my CB- so ignore that, OK? The 12V MOD is just the switch- that’s it. I also chose to remove the flip-down cover over the 12V outlet. I just plugged in my USB adaptor, which has a built in LED, and I have visual indication of whenever the outlet is powered on.
Still in? Read on, my friends…
Before you ask, yes this MOD can be performed for the rear 12V outlet the same way, or you can check out what my friend REATA did with his… HERE… :bigok:
** Continued
Can I just ignore this writeup, come over to your house with good, cold beer, and get you to do it for me? Please?
I already asked. If you want to fumble through this together let me know. I need to wire up my fridge and don't live too far away!
antman
Kingpin748 did a really nice dual battery install/ writeup...
Here's a link: http://www.toyota-4runner.org/5th-gen-t4rs/66190-kingpins-new-truck.html#post658420
I've never had a dual setup- so I'm sure he knows alot more about it than me!
All that weight you're losing is turning you girly. :)
Your thread is great because it's honest and witty, and very well written. It was popular before I came along- I'm glad I could add some MODS in between the funny stuff. You have almost 40 freakin' thousand views......!
When I joined this forum, I barely knew how to post pics and writeups. Now I'm hyperlinking, compressing files, making folders,etc. That was because of YOU (and others!), and I am having a blast.
That's what makes it so great! :D
You two need a moment? :D
Seiously :hatsoff: to you both. Truly inspiring.
Now that I have all these write ups, all I need is the balls to try half of this stuff on a 2 month old rig. And lot's of $$. lol
thanks bro , did my fog mod today , awesome job on the write up . now im jus waiting for you to do a write up on how to wire up a set of reverse lights in the rear . :bravo:
No problem! Glad it worked out for you. I know at least 3 others have done the rearview mod this week. Makes you wonder if any of us are watching where we are driving...? :)
What? No FRONT SONAR mod yet? tisk tisk.. Then you wouldn't have to watch, rather, LISTEN. *BEEP BEEP* STOP!!
Sometime soon I plan on doing a full writeup on my Gobi Stealth- including the lighting, how I ran the wiring and switches and all that stuff.
In the meantime, I received my Gobi ladder today :) I ran into the same problem as alvorbn did during his install. he did a nice writeup on the install HERE
I didn't bend the upper bracket to make it fit. I trimmed a little off with a Dremel and a fiber cutoff wheel. I touched up the bracket with some black Plastidip. It appears that the bracket is used for other vehicles as well(?). The problem is that the bracket hits the driver's side hinge underneath, which won't allow the bracket to sit flush on top of the hatch. I trimmed evenly with the big U shaped holes in the bracket to allow clearance for the hinge.
Here some pics of the underside of the upper bracket and where I trimmed it
You can see how it clears the hinge easily now. (The wires in the pic are power for the rack, and CB antenna)
Everything else worked out perfectly- but here are a few notes that may help you guys out:
** The aluminum strip that sticks to the underside of the rack needs to be placed right on the edge of the hatch, otherwise the set screws won't line up (sorry no pics)
** I bought this stuff at the Autoparts store and cut it to cover the hatch paint under the bottom of the ladder. I stuck the ladder's adhesive strip directly to the clear tape. Hopefully no rubbing (= rust!) for me...
Hope this helps someone- and for everyone waiting for their ladder- You will love it, I promise!:bravo:
ANTMAN MOD #4.1
Lighting up the FOG indicator from the FOG MOD
Now everything can go back together. The ground to the LED gets connected to the ground in the FOG MOD writeup, and the hot-lead ties into relay terminal#30.
Here is the result, whenever the fogs are on...
I performed this AWESOME fog light mod this evening (the wiring mod, not the led mod) and have two quick questions for anyone who has done this fog light mod.
1.) My amber running lights no longer work. The ones I am referring to are the horizontal ones next to the fog lights. I double and triple checked my installation and everything was by Antman's writeup. Any suggestions here? Has anyone else experienced this??
2.) Does anyone think that the green led fog light in the dash can work again (without wiring in an led)? In other words, can we wire the brown or black (now cut and worthless) wire from the fog light wiring harness in the stalk to the relay (the #30 pin)?
WOW. This Antman guy is out of control!
I was happy for a week when I programed my radio stations. Then I set the time on the clock and jizzed my pants!!
To answer your questions:
1- The amber lights are the turn signal- DRL. They won't light up with the parking brake depressed. Check that...
2- You can light the original green LED by grounding the brown wire- BUT- it only works when the fogs are on with the headlights. In other words it works the way it did before the mod. Your fogs will still work whenever you want.
I was hoping someone could figure it out, but so far no luck!
Glad you like the mod- Independent Foggers unite!
Thanks so much for the quick (and correct) answer!! I had the e-brake set while doing some of the wiring. So that was obviously an easy fix! I also plan to ground the brown wire today so I can at least enjoy the fog light led while my low beams are on! :thumb3:
Ground the brown wire attached to the little white plug, not the cut wire coming from the fog switch- just wanted to clear up any confusion.
...naaah. You should have seen my GTI. THAT broke my heart to sell!
Plus I think I'll keep this one awhile. I kinda like it :)
Hahahaha My wife will kill me if I touch her R32 ... but as long as she lets me drive it every so often.. I can live with that... I love that car! (just don't let my 'Runner hear that).
Okki :guitar3:
