10-24-2012, 11:41 AM
The Yeti Build
As requested...
Purchased from TTora member Wes (NastyNate) in 2/2012
His build thread: Project "NastyRunner" - TTORA Forum
How I got it: - Truck has 266K according to the Speedo,
- 65K on the Engine (from Japan)
- Rebuilt Automatic
- 35" Wrangler MTR's on AR 589's
- 5.29 Gears
- Tubbed front inner wheel wells
- Detroit Locker rear
- Lock Right front
- Rear Tube bumper and rock sliders tied into the frame.
- SR5 seats out of an 85 SR5
- GM 140amp alternator upgrade
- rear window works!
- body work to repair some rust spots
- new paint job; Brightside Polyurethane Hatteras Off-White 1990
- brand new starter and upgraded starter wire relay bypass (4crawler method)
My additions a/o 10/2012: - TG 4" Lift F&R
- Axle Trusses and diff armor
- 37s on 16.5s with self-welded rock rings
- High Steer
- Addicted Front Bumper
- Frame and bumper reinforcement
- Tube Doors
- 6 Shooter knuckles
- Late model 4R brakes up front
- GM master cylinder
- Front DS tube-lenthened. I'll go long spline front & rear when I get the duals in.
Plans - Full length 4xI cage
- Hydro Assist
- 4.7s are sitting in a box on my bench, waiting to go into one of the spare TCs (duals)
- Paint
Pics (2/18/12)
Pics (10/2012)
10-24-2012, 11:45 AM
Real Name: John
Real Name: John
SS
Username sounds faimilar.. haha
TW
Nice rig!
10-24-2012, 11:46 AM
Originally Posted by Jonny
SS
TW
Nice rig!
LOL...I self banned myself so long ago
Thanks!
10-24-2012, 11:57 AM
Real Name: John
Real Name: John
Thanks!
good move.
Place has been goin to s**t lately... lol
10-24-2012, 12:23 PM
Real Name: Kevin
Real Name: Kevin
So nice. KidV likey.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
10-24-2012, 12:31 PM
good move.
Nice runner looking good!
10-24-2012, 01:04 PM
Very nice rig! Welcome to the forum.
Former owner of four Runners: three 2nd Gens and one 1st Gen. After a long layoff, I'm back in another hardcore crawler 2nd Gen.
10-24-2012, 08:36 PM
Thanks fellas. I'm looking forward to giving it a shakedown at a local ORP in the next couple of weeks.
I'm finishing up the brakes this week. I didn't like the feel of the stock master cylinder with the huge 2gen 4R calipers, so I put a GM unit in and am struggling to get all of the air out of the lines. Hopefully finish it up tomorrow...
Reason: Fixed the caliper gen
10-24-2012, 08:43 PM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Well done! I like it!
Did you bleed the MC before you attached the brake lines to it? Not trying to insult your intelligence, just asking. If not then you may want to bleed that first.
Do you have any plans to cut the fenders to stuff those 37's?
10-24-2012, 08:50 PM
Yep. I bled it as best I could before hooking it up. I actually was worried about that so we tried bleeding at both lines entries again & only got fluid. I'm thinking that I need to adjust the drums in back & try again. It almost feels like the rears are getting full pressure before the fronts can engage. Since the rears set the pedal height and I'm getting pressure stop about 1/2 down, it's possible... thoughts?
The front wells are already tubbed on the inside and fenders flared & trimmed a bit. The rear is definitely gonna have to be cut....
10-25-2012, 02:42 AM
Real Name: Sam
Real Name: Sam
just a thought, but have you adjusted your rear prop. Valve. with the lift the front will be getting most of the stopping power. you can simply make a little bracket to lift the axle end of rod or just remove the bracket and zip tie it up. What size GM MC did you go with?
love the all white 1st gen runners btw looking great.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
10-25-2012, 04:46 AM
Real Name: Kevin
Real Name: Kevin
More details on the front brakes please! Did those 4gen calipers bolt up or did you fab a bracket? What rotor are you using?
10-25-2012, 07:20 AM
Thanks man. I hadn't thought about the BPV. I had planned to remove it and plug the line in the front pass wheel well, but never go to it.
I ended up just buying the entire kit from Sky, but the MC is the Cardone 10-1584 part number.
Toyota GM Master Cylinder Adapter - Sky's Off-road Design
Oh ****... typo. They are Gen2 calipers & bolted right up.
Note: you don't need the pads. The Fully Loaded kit comes with them.
10-25-2012, 07:59 AM
Real Name: Kevin
Real Name: Kevin
Harrumph. You had me all excited there for a moment.
10-25-2012, 09:29 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
What's the advantage of the 2nd gen calipers and the other brake discs? Bigger brakes and stronger calipers?
