Originally Posted by Orev
Thanks for the valuable write up!
I am still slightly confused with a few things,
1.In the pictures you are changing the bushings on Rear Tundra 5100's.
2.Does this need to be done to the front shocks as well? I am installing Front Tundra 5100's (f4 be5 6929 ho)?
3.Also I have been told the rear Tundra 5100's are too short for a 3 inch lift is this correct??
This does not need to be done with the fronts. They are already the right size.
The Tundra 5100's with a 3" lift are perfect. No worries. If you want some more travel you could look into Bilstein 5125's.
