Originally Posted by rgcary
Thanks gaterose. Yeah, I have a v6, so I'm guessing mine would sit a little higher in the front with FL springs. How much taller are FJ springs when compared to 4Runner springs? Is there currently any spacers used on a stock 4Runner suspension and if so should they be removed with the FJ spring install?
Not sure, how much taller but they usually provide .5-.75" of lift after settling in. There are no stock spacers.
Also forgot to answer one of your earlier questions - with the 5100s you will have to remove the setup to adjust them unless you purchase the toytec adjustable conversion kit for $460.
