View Single Post
Old 09-06-2012, 03:50 PM
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Originally Posted by boondoggle View Post
Not to derail too much but….
How effective do you think it would be to drain what you could from the system, then just pump new fluid in until you reached the fill hole - without doing the full blown change at temp procedure as described in the FSM?
How many quarts do you think that would replace?
The only problem is these sealed units are finicky about being under or over filled. If you filled it until it dribbled out of the fill tube, you've filled it too much. You need to undo the overflow tube and fill until fluid starts coming out of it, then warm it up to the temp range and make sure it only drips a little then you're level is perfect.
BlackWorksInc is offline   Reply With QuoteReply With Quote
