Originally Posted by rbrownlie
Which model? I would start by asking myself why do I want a 4Runner and how do I plan to use it. Based on what you say about your intended uses, a Highlander is probably your best bet. It will get you through the snow and light off-road, and is far more economical. As for 4Runners, your intended uses seem to suggest you do not need a TE. That leaves you with an SR5 or Luxury. If money is an issue or you do not need the options that are bundled with the Luxury, then its an SR5. If you need or really want those bundled options, then it is a Luxury.
Personally, I chose a TE with KDSS because I wanted a highly capable off road vechicle. It does everything I want on the road. It had no problem bashing around bad lands and dessert loaded with guns, ammo and passengers on a recent hunting trip (far better than my former F150 FX-4 when it was stock). Fuel economy, however, is the price for that off-road capability. Hence, my prior suggestion that you might also want to consider a Highlander.
I may be wrong, but isn't the mpg the same for the highlander and 4R?
2010 SR5 4x4. OEM running boards. Cheap Autozone mud-flaps, used on rears only. Go Rhino hitch step. Rear storage area mod. Shrockworks front bumper with black Smittybilt shackles and yellow Daystar D-ring isolators. Duratracs 285/70/17 D. Satoshi Yoda mod
Toytec Boss lift kit and LR UCA.
