Originally Posted by SV_Dude
Correct me if I'm wrong but isn't back pressure a bad thing? You want a free flowing exhaust that reduces back pressure. The more back pressure you have then that is more that your engine has to work to expel the exhaust gases from the cylinders.
Standard engines(ie not turbo charged,.....) are designed, and need a degree of back pressure to run properly. One can argue if the factory setting is optimum for performance, but virtually zero back pressure is a bad thing, especially on that type of engine(ie 4 cyl). The last thing you want is a ton of fuel dumping down the cylinder walls.
regards
