Real Name: Kelly
Real Name: Kelly
Check Engine P0171 Code
I know this has been covered many times but I need help! I have a P0171 code that I can't clear. I have replaced the MAF, 02 (both), fuel pump, engine temp sensor, all OEM Denso. I also replaced the PCV. I replaced the T-stat with a TRD. I also checked for vacuum leaks. The code will not stay cleared. Has anyone had this same problem? What did you do to fix it?
